Huawei Mate 10
muddle
I am also puzzled with your point 1 as well. I believe you can find it if you use the file explorer, but I did not try since I don't have a problem with storage space for now. :s13:
Albums
Scroll down
Recently deleted
Clear
symbiote28
urgently need some advise here. my hisuite suddenly does not detect my phone. phone and hisuite are on latest versions. when i plug the usb-c to the pc, i click on allow access for usb file transfer. there should be another pop up for me to click but somehow for the past week or so, it never appeared.
haylui
Anyone has problem with their mate 10, automatically turn off the GSamBattery and Internet Speed Meter lite ?
Means after several hours of running then suddenly disappeared in the background. Need to manually turn it on again.
So far the phone wasn't restarted because once restarted it requires pin to unlock instead of finger print.
OutBreak
I have stop using Gsam battery monitor. It seems to stop working well with Oreo. It didn't show which app is sucking the most battery. Do you have the same problem?
haylui
Yes. Similar issue but mine is completely turned off from running.
Only internet speed meter lite and GSamBattery have this problem. Other apps run well.
OutBreak
Have you check the "launch settings" to manage manually. Probably EMUI keeps turning it off to save battery.
Btw, Gsam battery has a weird phone permission requirement that cannot be turn off. I have switch to using AccBattery. See how it goes.
leon0079
Anyone experienced Bluetooth earbuds suddenly no sound?
Sound out from phone speaker instead
Still shows Bluetooth connected with my wf-1000x
Initially thought is my Huawei watch Bluetooth interfering so I disconnected my watch but still experienced the same thing.
HuatKway
Alot of us having this issue and have feedback to Huawei. Do send ur feedback to them too
leon0079
Alright will do.
I further confirm by testing with my iphone.
Running perfectly without any issue.
At least can verify my earbuds are functioning properly haha
Googled and found out its like Oreo's fault. Hmm thought of changing phone but seems like the latest ones are all on Oreo and will face the same issue.
OutBreak
Alright will do.
Indeed.. The Bluetooth issue is already discovered during Oreo beta. I always believe it never a good idea to remove the 3.5mm audio jack.. Bluetooth on Android is too unreliable.
micshang
Any app to auto hide the navigation bar?
Hope the next software update comes with this function
muddle
You can always use the included usbc to 3.5mm adapter
ComputerTime
Hi,
Has anyone tired to pair Mate 10 to Logitech keyboard 375s? My Mate 10 cannot detect the keyboard, and I do not know where does it goes wrong. I used to be able to connect the keyboard to my Note 3 previously.
Regards.
Incursio
Is there any shop which sells a tempered glass screen protector along with the mate 10 pro? I rather have it applied once I purchase it.
