Huawei Mate 10
etoilebiscuit
Is there any shop which sells a tempered glass screen protector along with the mate 10 pro? I rather have it applied once I purchase it.
Can try peninsular traders. I bought from there and a tgsp and applied on the spot .
Sent from HUAWEI BLA-L29 using GAGT
UVERtainment
can anyone share a brief review on this phone? (the normal ver, not the Pro)
i'm tied up between mate 10, s8 & 5T. i would've gotten the 5T if not for the camera
knave
Speed demon,
Great camera,
Ok screen (just dun put beside an AMOLED phone)
Great size / screen ratio (vs others that are too long).
Nice battery life
Great price for a flagship + 2yr warranty
Speakers are better than any Samsung, including ring tones playback
Super super fast charging.
Super useful gestures for taking screenshots.
Cons:
Abit heavy
Emui over aggressive on battery optimization
Oled notification light too dim, next to useless.
Front camera over exposed.
maumu
anyone can find a tgsp that can stick on the edges completely?
so far the ones i got (including from Huawei official store itself) the vertical edges cannot stick on completely...
CS0287
The one I bought from qoo10 also same, one side cannot stick completely
maumu
Just to share Nova launcher prime is on sale for 0.99c
Best buy for a great launcher
does it have any conflict with mate 10 pro? and.. does it have double tap to wake function? i'm currently using mate 10's own tap to lock widget. will it cause any conflict? am happy with tap to lock but missing the double tap to wake I used to have in my previous phone (xperia z5)
KeYoKe
no double tap to wake. if you are using third part launcher, the mate 10 tap to lock widget will not work (u cant even add the widget to your home screen)
maumu
thanks.. then i'll give this nova launcher prime a pass. was hoping it will have double tap to wake.
i don't mind not using the Huawei tap to lock widget if the launcher has both double tap to wake and double tap to lock. but alas...
leon0079
look for white gap filler (some sort of glue which you can fill in at the edges to remove the bubbles)
i bought one from alixpress which came with the filler glue; came with video link on application process
I managed to remove the white gap like 80%
was playing too much with the glue end up not enough lol
deckcard
Double tap to wake is not a launcher feature but the kernel support (which it has but not enabled in the build.prop). Double tap to lock is a launcher feature which HW has a widget for it but Nova has gesture features that can enable double tap to sleep (using timeout instead of straight lock works better on unrooted phone), swipe up to access app drawer and down to access notification that is missing in most launcher including HW EMUI
knave
Once you used nova launcher gestures, you're stuck with it. No other launcher comes close yet.
maumu
i really think they should have it one day.. because the FP is on the back. so when u want to read notifications or just the clock, u can't do it without either lifting up the entire phone to touch the FP, or press the power button on the side.
that is just about the only thing I dislike about this phone for now lol..
knave
Only the Pro. That's one of the reason the non pro is more enticing
deckcard
Even with AOD, there is no dttw or ambient display?
hongge
I have used many screen protectors for my mate10, tried PET non tempered, full screen tempered with white gap filler, 3D black border tempered which used glue ... but in the end the best screen protector for me is the non full screen tempered glass from taobao. no white border and good fingerprint resistance.
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4521ef11fWf5vY&id=543529710693&_u=r1mkshf79a6d
Froggyman
It's for the bokeh effect right ?
Should be =:p... Yet to try it out.
Initial explanation i found out is :
Portrait mode : Enable Portrait mode to automatically apply beautification effects to everyone in the frame.
Later i did find out it for the bokeh effect.
Thank for your info.
