Huawei Mate 10
jiayelim
Jaybird X3
Did you face any problem like below? asnd how long have you been using this combination (Mate 10 pro + Jaybird X3)
"during continuous use, the connection will randomly drop off when i do something such as launching game, turning off screen or sometimes when there is an incoming call. Actually the phone is still connecting to the bluetooth earphone but the sounds come out directly from the phone speaker, which is SUPER ANNOYING."
HuatKway
Mine is exactly the same issue.. Jaybird x3 too. Ahh
DiCaprio
Could it be a jaybird issue? I've been using my Bluetooth earphones (erato Muse 5) for a while now, so far no issues..
Sent from Tomorrowland using GAGT
gt_5454
No issues for me both on Bluetooth headset and car stereo. Music plays throughout.
MichaelTan
I realized Huawei didn't handle 2 Google's accounts well enough, not sure if it's the fault of Google implementation.
For example, I have 2 Google accounts added. One of it with location history on and another with location history off.
But Huawei settings treated them the same. So if I go to location history settings it will prompt me that my location history is off.
When I turn it on, it will apply to both accounts and likewise if I turn it off, both accounts are off. Even if you specifically switch to another account to change the setting.
So far this is quite frustrating for me as one of my account is work account and I don't want anything turn on for it... Haiz...
location settings is based on PHONE not account, hence when you ON you ON for ALL and when you OFF you OFF for all accounts. I have 3 google accounts. it's the same for all Android phones 7 and above.
aakish77
Wow, so much issues on Mate 10 Pro...
The issues I had was apps going crazy after:
Using phone clone to transfer from Samsung device(there were some Samsung app framework got transfered too)
Installing a 3rd party launcher Nova + sesame + tesla unread which screwed up my Theme store and stock widgets
Facebook + messenger(uninstalled them) which keeps interfering with youtube.
Changing screen resolution to HD and this made the phone fonts and icons go haywire.
I made a clean factory reset and refuse to use built in Facebook /messenger or any 3rd party launchers and things are working great for now.
Notifications are working just fine.
Earlier I got the Remax Bluetooth earbuds and yes the sound was sometimes distorted because it doesn't support Aptx codex.
So I got myself Huawei AM60 about few weeks back and no issues since then. Never had drop in sound etc.
Oreo 8 is just like JB before kitkat and Lollipop before Marshmallow when it was first released, a lot Google play apps could not get used to it until several updates, and finally a new version released.
andyhtc
Suspended
That's good price. Is that original and comes with 3pin plug?
Yes, it looks and works like the original, so I guess the owner gave up his original charger.
There was a 2-pin version at just under $30 though so be careful to check to ensure you are getting the type you are looking for.
meekiatah
Good deal if it's original. The 2 pins one that you mentioned should be China version.
knave
No issues running Nexus launcher with Tesla unread here. It's probably due to the cloning that you performed that copied over unsupported files. Try do it from fresh instead
