Huawei Mate 10
linusz
For mate 10
How come when I click an email address in chrome it will not use the default Gmail but prompt me to select email service to be open by huawei
r0_ger
Looks OK from mine but is there a limit to the number of scroll? Mine didn't last to the last page
Wait, why resolution like that??
Sent from HUAWEI Mate 10 Pro using GAGT
Found out the issue... I set my screen resolution to auto. So it kinda screwed up. Just keep to one fixed resolution and it's OK now.
sgsleeping
Battery like jialat in the latest update
Anyone affected?
Sent from HUAWEI ALP-L29 using GAGT
hermes76
My smart resolution is off leh, if that's what u were referring to
sgsleeping
Just to check what happen to the batt. Was considering to get M10. Drain very fast or other issue.
Currently 47% after sot 1hr 53min.
Light usage such as web browsing etc
watzup_ken
For mate 10
Did you set the default app? I never have this issue before.
watzup_ken
Anyone affected?
What is the version that you have upgraded to?
I stopped at 131 waiting to see if there's any issues. So far no issues with battery and still lasting 2 days for me easily.
linusz
Yes I set Gmail as default
It ask me to add account and choose between the email clients
Is it the mail to settings for chrome or Gmail clients or phone setting?
jas1701
went to singtel shop and try on the M10. Where is the back button any1 kn. I hv to press the home button to go back default hom screen. Then if I go to settings and check something, have to press home button again.
haylui
Hidden already.
Swipe from screen bottom and you will see.
OutBreak
You can go to settings and search for virtual navigation bar. Probably someone turn it off.
linusz
Had to disable huawei email client so that email link can trigger my selected Gmail.
Anyone got this problem too and know how to resolve?
haylui
Have you set the default apps into Gmail?
Go to settings -> apps & notification -> default apps -> email
Then you can choose from a list email client...
