Huawei Mate 10
CS0287
Have you set the default apps into Gmail?
Go to settings -> apps & notification -> default apps -> email
Then you can choose from a list email client...
Tried... Tap on email link still open email app by default
jas1701
Regarding the email, r u all checking office or ur own gmail acct. If I need to check office, I go through browser with address end in OWA. As for gmail I just type gmail.com and login. I dont set email for push notification.
OutBreak
Currently 47% after sot 1hr 53min.
Light usage such as web browsing etc
Sent from HUAWEI ALP-L29 using GAGT
Probably you have some rogue app running in the background? Like FB?
The battery life for my Mate 10 looks fine.
r0_ger
My smart resolution is off leh, if that's what u were referring to
Sent from HUAWEI Mate 10 Pro using GAGT
Yup Smart Resolution not so smart. Switched it off and went with full HD. No issue with scroll screen shot or multi views
Moodee
May I know if I want to extract text from my screen (either website or app etc), is there a way to do it on Mate 10? I used to do it on Samsung Note with the stylus but I understand not all phones have this function. Thank you!
wuming79
Has anyone mentioned about the Huawei mate 10 auto reboot issue? My mate 10 reboots 2 to 3 times a day without me doing anything. Wonder if there is a fix to this beside factory reset?
knave
If you dun mind the long method...
Print screen
Save pic into onenote
Go to one note on pc, sync it
Right click on picture, select copy text
Moodee
Print screen
Thanks for the suggestion! Appreciate it. Don't mind as I gotta do it for work sometimes :)
Moodee
Realise mate 10 doesn't have built in OCR so I may have to download a 3rd party app?
Audiology93
Just bought the Mate 10. Miss the 16:9 display :s13:
No more black bar when watching YouTube videos
gt_5454
Yes 16:9 always good when watching YouTube as nowadays most phones are 18:9 etc.
Which phone were you using previously ? What’s your impression of so far ?
Audiology93
Mi Mix 2. Camera on the Mate 10 is very good compared to the Mi Mix 2 and not having to carry around a headphone jack dongle is so much more convenient. Everything seems so much bigger on the Mate 10, and it's kinda fat :s13:
Welcome to the club.
Thanks!!!
haylui
Try factory reset. My mate 10 also does that before I hand over it to my wife. After I did a factory reset I don't see that issue.
Mate 10 pro totally has no such issue.
wuming79
Is there a way to save all the apps and restore them after factory reset?
haylui
Try the backup and restore function?
But some social apps like wechat and line are unable to preserve the chat history in the conversation box if you do so.
Other apps should be no problem.
Audiology93
My Mate 10 seems to be changing the brightness on its own depending on the app that I'm currently in. Is there anyway to disable that? I've already turned off auto brightness.
