No way to disableMy Mate 10 seems to be changing the brightness on its own depending on the app that I'm currently in. Is there anyway to disable that? I've already turned off auto brightness.
Sent from HUAWEI ALP-L29 using GAGT
Your mate 10 bought from SingTel?Has anyone mentioned about the Huawei mate 10 auto reboot issue? My mate 10 reboots 2 to 3 times a day without me doing anything. Wonder if there is a fix to this beside factory reset?
I didn't ..... Did you restart your phone? I feel like Android phone is kinda like windows computer, after awhile need to restart. Then everything will be smooth againAnyone experience slow down in mate 10 pro?
Today my phone is like in slow motion.
Storage left 75GB. So don't think related to storage
Few months in. Mine still feel pretty snappy. I restart it every morning.Anyone experience slow down in mate 10 pro?
I cut off their apps access to mobile data.Did restart a few times. I guess maybe SingTel installing apps in background again... really sick of SingTel download all the unnecessary apps back every time I uninstalled them.
Now the phone back to normal again.
Oh damn. Thanks. Thought there was something wrong with my ambient light sensor.No way to disable
I put them in a folder. If u delete, it will come back. Just ignore them.But the app stay there or how to do the settings?
Magnetic USB cable don't support super charge. Super charge only work with the provided adapter and cable(and some 3rd party cable like ugreen which support 5A)Anyone using a magnetic USB cable with their Mate 10 without any adverse effect on SuperCharge?
Doesn't happen to me leh. I got the 134 update as well. And the battery life is miles better than when I was on 131.
