Huawei Mate 10
Funky2
Any idea what's this batt-like indicator? Dun tell me is the batt level of my BT device? Got so smart ah
Sent from HUAWEI Mate 10 Pro using GAGT
Yes, it is one of the feature that Huawei UI has.
Btw mau I ask if the Bluetooth sounds ok? Is there crackling sound.
Sent from Samsung SM-G955F using GAGT
hermes76
I'm using on RB-S10 no issue if within range, no problem with my Charge2+ also but my Uproar seems weird lately, like is able connected to other pple devices which I dunno how.
Skyy
It's not a Huawei exclusive thing, it's an Oreo thing.
symbiote28
My 128gb should be coming next week. It is a Samsung Evo+. Will update u after test.
Sent from HUAWEI MATE 10 using GAGT
i've been using a 128gb with no lags. just wondering if anything above it would show some slowness.
symbiote28
I am trying to transfer Data from my phone via cable to my pc but looks like all my cable are charging cable. Anyone has knowledge where to buy data cable from qoo10?
get something like this. i have a couple of them, works fine.
https://www.lazada.sg/products/original-baseus-5a-speed-type-c-data-usb-cable-port-qc20-30-quick-charger-100cm-for-huawei-mate-9-nexus-6p-xiaomi-samsung-intl-i227292697-s347432006.html?spm=a2o42.searchlist.list.35.7a635ff6RPmWDn&search=1
watzup_ken
dreaded this day. SD card died on me. kept getting 'sd card damaged, replace current card' error. only happened when i tried to backup my stuffs to my NAS.
I think 4 years is pretty decent. Not sure about your usage, so can't really conclude if it was due to high disk activity/ write that caused it to die.
Anyway, SD cards are not known to last. I have had SD cards that failed, and one in less than a year.
symbiote28
yup 4 years is quite good comparing to my others too.
Why would it lag? Unfortunately, I don't have a Mate 10, so I can't try this out.
just bought a 200gb in the afternoon, no lag whatsoever :o
TheOutsider
Mate 10 (4GB/64GB) vs View 10 any clue?
Which will you pick?
Both super closely priced right now. *facepalm*
Igene
Outlook I go over View 10. Camera I go over Mate 10 (OIS).
Some may not like longish screen too.
TheOutsider
2 years warranty vs 1 year warranty, OIS, potential to get P20 Pro kind of night mode, 4GB vs 6GB, 64GB vs 128GB etc etc.
So hard to decide between the two. Headache haha
Oinkize
Mate 10 of course. Else mate 10 pro.
haylui
Which ever is lower in price.
Nowadays seems like Huawei is focusing on the Honor sub brand to tackle middle level phone.
Like those phone priced at 5xx also using 970 SoC
Audiology93
Camera, go for Mate 10
RAM/Storage, go for View 10.
Personally I'll go for View 10 for the higher ram and storage.
kingstarfly
Thinking of buying a second hand Mate 10 / Mate 10 Pro. But I've been reading this forumn and there seems to be complaints of bad battery life?
Can anyone point out if it's a matter of manufacturing batch (nov-dec 2017 vs mar-may 2018) or firmware (which firmware is the problematic one?) or specific to one of the two variants (non-pro vs pro).
Would greatly appreciate any help and opinions!
charleslin
To be honest I don't really think there's any issue with bad battery life.
Maybe sometimes firmware makes the battery life not as good as the previous, which can be possible, but still it's way way better than any other phones out there.
