Huawei Mate 10
CS0287
Same... The moment I switched to my expired Thai sim card, I got the update... So glad that i kept the sim card after my trip :s13:
But at the same time I am so disappointed, we stayed in Singapore, but using sg sim card cannot get the update. What the...
progene
My pattern screen password feature gone after update to 9.0..anyone encountered? Current only pin, face recognition and finger print available nia. Did a factory reset but still the same.
I got 2 mate 10, the other one ok but this one no more pattern password feature.
Mine still here.. just that I could not find the settings to amend it (if I wish to amend the pattern)
Sent from HUAWEI ALP-L29 using GAGT
Shib
The battery drain pretty fast under the new android...
Sent from HUAWEI MATE 10 using GAGT
ukyo100
Battery from night 10pm 100% until 6am still show 100%.. May be my phone very less app for notification.
j4nfz1981
Like what Shib mentioned, what I did was to change to another sim (tried another local service provider though), went hicare n try update again, n the update magically appears. Thanks btw.
A.r.S.e.N.i.C
My battery dropped 6% overnight despite having wifi and data turned off after the new update, anyone else experiencing the same issue?
mun
Just managed to update mine yesterday night. I also waited 2days and got fed up as unable to do any upgrade. Since some bros were able to upgrade using foreign simcard, I removed all existing sim and used my unused circle.life sim and hit the update icon in Hicare app. Viola.. The update appeared.
So guys, you might want to try this method, using other local sim (borrow from other family members or friends)
Good luck
Posted from PCWX using BLA-L29
CrispyPeddler
when i first updated over emui 9, i notice battery drain fast too. and overnight (off data off wifi) reduction of battery life like 5-7% in which emui 8 overnight (off data off wifi) like 1-2%
but after use for several day, not sure if its due to AI or whatnot, the battery life improved. yesterday night 100%...wake up to 100%...i would presumed its AI optimizing based on your usage or something :s13::s13:
jameshong
I think android 9 not stable..saw some website said pattern password missing or haywire...regret to update it!!!
svpreme
im also on singtel, just put any expired simcard and will push the update to your mate. now all my widgets and themes are weird. need to recheck all your apps
etoilebiscuit
My camera app keep hanging. Wiped camera app cache and let's see for now. Update again.
Sent from HUAWEI BLA-L29 using GAGT
KYLee
Interestingly, after a few days of usage, battery life seems to be better den before thr update. 3hours 30mins SOT with 46% left now!
mun
Today is my 1st day of usage after update and the battery sucks. Hope the battery will get better and better as days go by :s8:
CrispyPeddler
yea same. today my battery even better. till now still 50%. i think the AI is not a gimmick
do monitor for few days. first day updates my battery also quite bad. now seriously improve alot...like ALOT :eek:
