Huawei Mate 10
OutBreak
Anyone find that the virtual navigation home button is buggy? Sometimes need to press 2 times to respond..
rarenick
Finally during Christmas party borrowed my sis m1 sim card to test updating my mate 10 pro. It worked!
Posted from PCWX using BLA-L29
j4nfz1981
I used to be able to hide messages eg sms, whatsapp from lockscreen in orea via setting peeking mode.
In pie, the "Lock screen notification which is set to" show but hide content doesnt work now. Anyone got it work?
amazingone
Did you setup face unlock too?
Posted from PCWX using HUAWEI ALPS
amazingone
yes, but I faced the phone away to make sure its not detecting any face.
That's weird, my notifications only show content when it detected my face. Otherwise the content is hidden.
haylui
I keep refresh the system update under settings cannot see new update until I read forum here and go to HiCare...singtel user.
After update the Facebook account also removed. Some apps are incompatible.
Paul Lee
Which apps have you found to be incompatible?
The only one I have a slight problem is either Musicolet or ACDisplay.
When using Musicolet and locking the screen of the phone, the volume goes haywire.
But that's just a minor annoyance rather than an outright incompatibility issue.
newcell
Done my mate 10 upgrade 2 days ago.
Did factory reset a few times.
Before I re-install all my app, not by restore method.
So far everything works smoothly.
All major firmware upgrade need to factory reset (clear all cache) and re-install app.
j4nfz1981
Delete all settings also cant work. My lockscreen also cant seem to work. tried all settings but to no avail. Dun know whats the root cause. End up just factory reset again and reinstall all app. Its all working like BNIB. :s13: Anw, Huawei device really need to know how to set battery optimization, background launch, etc. My apps used to be closed or got launch restricted by them. :s22:
OutBreak
I think I have to try reset also.
