Huawei Mate 10
rarenick
All the less developed countries compared to sg are getting the update before us. Sg really shortchanged.
Posted from PCWX using BLA-L29
deadman4168
Those who are still not getting update, try to change region to singapore in Hicare app if not already done.
Mine was set to europe as soon as I changed to sg, got the update.
charleslin
I can assure you Singapore is one of the fastest, other than China of course.
Go XDA forums and see, a lot of them still stuck in security level before Oct.
amazingone
Huawei seems to be slow in pushing updates in the European region, saw quite many Europeans asking Huawei when will their phones get updates.
charleslin
Ya.
Anyway it's Android issue in general.
They should check out Samsung for Singapore then they know what is called slow updates. :s13:
I have a Note 9 from Indonesia that updates faster than Singapore.
Shib
What is your hicare version?
Sent from HUAWEI MATE 10 using GAGT
Suhr23
Same lol. My warranty to 2020 but shows expired. I think their system may have glitch.
Can check your warranty. Mine shows expired but expiry date is year 2020.
Shib
Updated the app but still nothing for my set...
5408854088
How come now will auto connect to wireless at sg? Didn't even login or something got free WiFi to use?
5408854088
Anyone enable WiFi calling? Understand that if in local, they will deduct from call time. How about when overseas? Anyone got experience to share?
KYLee
can see immediately the battery life is worst on my mate 10 non-pro.. used to get 5-6 hours SOT.. today only 3 hours 30 mins and my battery is already at 30%...
TheOutsider
Wireless@SGx is free for use. Just that with a local sim card in, the phone can auto connect with PEAP-SIM authentication which use the SIM card as the "password". It comes with all 3 major telco. Singtel has the advantage of using singtel wifi on top of wireless@sgx
CrispyPeddler
same. battery seems to be draining fast in emui 9. trying to find whats running in the background
