Huawei Mate 10
eyz
just changed my frame + LCD screen on my mate 10.
it's kinda easy even when the back case is sticker with sticker.
irfans
dude, how much did they charge you for the frame? And does the frame come with the back cover as well?
eyz
I changed myself bro. $80 for a refurbished frame and LCD.
I think HW change the screen for $191 + $35 labour + GST, not sure whether it's including the frame or not.
cybertech
Is there actually a full screen privacy screen protector for Mate 10 (non-pro) available? So far I seen and bought all will leave a small gap around the screen. Only those normal screen protectors will cover the whole screen area.
linusz
Anyone have their hicare icon missing on mate 10 after 30th Jan update for hicare
Any idea when is the next firmware coming
Posted from PCWX using ALP-L29
amazingone
The HiCare app got renamed to Support. Search 'Support' can find the app.
I think the next firmware update should be EMUI 10, now it's undergoing beta if I'm correct.
Posted from PCWX using HUAWEI ALPS
jingy1711
Wow, i just realised hicare app is missing.. cant wait for EMUI 10, have been camping for it for so long..
barnabaskoh
I have a mate 10 pro that is available for the change of battery 49.90, I can go down to Huawei on anydays to replace at this price right? no need to wait for their Huawei monthly once event which was temporary cancel right?
linusz
Back of phone was scratched and with crack line
What would be this piece. How much to replace ah
Anyone done this before?
Thanks
eyz
$54 (parts) + $35 (labour) + 7% GST, gotten from the Huawei website.
can change it during 1st Sat and Sun of the month, to save on the labour.
or buy from AliExpress for less than $10 and change yourself. you need a heat gun to release the double sided tape between the main frame and cover.
Thanks
amazingone
Hahaha! Are we still getting this update?
Delayed to mid-June.. :s22:
https://www.huaweicentral.com/emui-10-for-huawei-p20-mate-10-series-in-europe-delayed-to-june/
