Guys, I am used to having a home button on my LG V10 which pull down the notification menu.
I really miss having it in Mate10.
Any idea how I can get this feature back?
Do you mean this? If so, Mate 10 has it too.
Ah, but Mate10 has make me greedy. I am now used to gesture on fingerprint sensor and don't wish to turn on the usual navigation buttons.
Hmm... Running Oreo too early has its negative side.
4 of my Apps are not compatible with Oreo. Cannot install yet.![]()
Did you try sideloading these apps? Some of the apps can still work by sideloading
Haha. Too bad then lol.
I'm also using button navigation on Mate 10. Awesome. More real estate for apps and contents display.
speaker output is quite good, can go quite loud.
My perfect solution is for the off screen navigation to include a gesture to pull down the notification menu.
That will be truly awesome!
I'm using Oreo on my Nexus 6P since Sep, all my apps having no problem running. No issue at all. Which of your apps are having compatible issue?
.... but it is there.... Under Fingerprint ID, Slide Gesture.....
I tried to install 2 and 3 on my phone, they have no problem launching.Okay! These are the apps:
1. PhotoDirector
2. Flightradar24
3. KFC Delivery
4. Google Earth
Among them, No 2 and 3 are super-duper important to me!
