Huawei Mate 10
Gash_1989
End up gotten a brown 10 pro as the blue isn't the blue I was hoping for, compared both mate 10 and pro but prefer the grip of the pro. Guess for now need to find a screen protector and casing. :D
p0108007
Just checking which card gives $20 cashback? If dun mind sharing!! Thanks!
Theres a few qoo10 seller selling at 868 now but either with MiPowerbank or Earphone. Hmm
harky
after seeing SH price for XS plan.
Compare Mate 10 pro & samsung note8 .... the price is like 100 diff..
$699 vs $789
U think which is worth to buy?? now i stuck there..
muddle
$699 vs $789
Both should be good. But what made me get the pro is because of the curved sides and the smaller battery capacity on note 8. Some might argue the lack of 3.5mm jack and sd card slot. Personally i find the 128gb should be ample enough. Lack of audio jack not a dealbreaker since the battery should be able to last longer usage
knave
OCBC 365. 3% Cashback on online transactions (and dining and groceries) , capped at $80 monthly cashback, min spend $600/mth
BOC Family card better @ 5% cash back for online purchases, just sharing.
junjie433
Thanks so much! It's a nice phone, I must say and I appreciate the big screen for reading.
I bought mine for $888-$110-$20(shop voucher) - $21 (qoo10 gift voucher discount) - $22(credit card cash back) - $30 (resale of free gift) =$685. Not too shabby :)
:eek::eek::eek: imba
HuatKway
Can I check how do games look like on 18:9 aspect ratio? Are they stretched or have borders?
vaxvms
personally i find the 128gb should be ample enough. Lack of audio jack not a dealbreaker since the battery should be able to last longer usage
u will miss it when u need it ...of cos not always
maumu
Different sellers in qoo10 are offering so many different freebies for mate 10 pro. But mostly those items which we dun really need. I dun see any seller that gives free hdmi adaptor. :(
Sent from LGE LG-H990 using GAGT
i guess it depends. i ordered from one which gave a 7500mAh power bank (ok, not that high but with supposedly quick charge @ 2.1A) and also data/charging cable. but the plus point is to use the $110 discount from qoo10.
Zappalapa
im comparing a number of freebies from diff sellers on qoo10
lazada is giving a Mate 10 Pro Flip Case, but only has around $30 discount (11/11), while qoo10 has $110 (11/11).
maumu
yeah, was considering the flip case ($68) but then again I asked myself, would i have bought the case anyway?
and the answer was no (cos it'll just add to the bulk and weight). i usually use a back case only and the phone comes with one. so i didn't go for the lazada one.
the $110 from qoo10 was enough to affirm my decision.
symbiote28
anyone got problem syncing their emails? i turned auto sync on so i manually pulled down the list. the last sync time is whenever i manual sync it but no emails are coming in.
