Huawei Mate 10
OutBreak
9S7jT
https://imgur.com/gallery/9S7jT
Hi, does anyone know how to remove the irritating ads at the bottom of Chrome browser on mate 10 Pro?
It should be hwz ads.. you can use adblocker like Blokada.
5408854088
I think I still prefer Note8 haha... Bought a Mate 10 Pro just to test it out. The lack of the Pen just breaks the deal for me :(
Prolly gifting this phone to my best friend for free anyways since he is a Huawei fan.
And also, OLED burnin problem can be avoided just don't leave the phone on a static image for hours at high brightness levels. That should prevent the burn in haha. From my experience just saying.
It is an inherent issue with OLED that it will have burn in after sometime. That sometime might as you have observed comes in few days (with LG's PLED) or longer. Based on my observation, flagship phones are all starting to move to OLED due to the brilliant colors/ contrast, and the main reason I suspect is because it is plastic, so it can be bent or have odd cutouts/ designs. This gives manufacturers more leeway when it comes to design of the phone, as oppose to a flat piece of glass IPS screen.
Depending on how fast one change their phones, they may not experience much issues. Anyway, I have seen a lot of people using Samsung phones using AMOLED for couple of years now, but the screen still seems ok. At least I did not observe any burn ins. So may be it may not affect phones using AMOLED.
In regards to the burn in issues, it is easy to get burn in even without high brightness level. For eg, AOD can get burn in if the image is static after some time. Navigation bar that tends to be static can get burn in also.
It took Samsung quite a few tries to get things right also when they introduced AOD and they fixed it by moving the image around (even if it's just a few pixel away so image may still appeared static but it as actually moved a little) after sometime so it doesn't get static. It takes the manufacturer's awareness of such issues and fixes to reduce burn in on screen but it also depends on user and the apps they used. For instance, if user run certain apps daily for long hours, there would be certain places on the app that remains consistent and static. So in the long run, burn in on those areas can be seen. Also keeping navigation bar on may not be a good idea so having immersive mode will help.
Anyway, I dunno if Huawei actually has this "moving pixels" in place on the pro phones with AOD and if immersive mode is on nav bar so I guess time will tell if Huawei does things correctly.
Can only wait and see how mate 10 pro performs. So far pixel 2 XL, iPhone X, and V30 all have this issue. Hopefully they can fix it.
watzup_ken
Full charge since morning 7+AM. Good?
I think it is difficult to determine just looking at the up time. It really depends on what you are running on it. I can game on it for an hour, and cause the battery to deplete quite fast.
maumu
i'm very excited to wait for the arrival of my mate 10 pro blue (currently with qxpress, hopefully will arrive tomorrow!). it would be my first non-sony phone in over a decade... (since the sony ericsson days)
does anyone have a guide how to transfer over stuffs from one android phone to another? I kinda want to transfer over things like sms and WhatsApp. the rest (photos and music files) can be done via usb transfer. but I've never succeeded in transferring WhatsApp and sms in the past. anyone got expert advice?
slimer
same like yours, may be tomorrow will receive it. android to android i think easier, i think try login with gmail and sync everything. you can backup ur whatapps to google drive first.
deckcard
1) for sms and calls history use SMS backup and restore from playstore. Setup to backup to google drive so restore also from Google drive. Fairly straightforward
2) WhatsApp go to whatsapp settings -> chats -> chat backup to backup to your Google drive. When you install WhatsApp on your new phone, it will ask if you want to restore. Dont miss that message and choose that.
beast
what abt whatsapp on ios, can only backup on icloud so how to restore on andriod?
HuatKway
Ahh wanted to get blue today from starhub but seems like most stores are Oos including the online store. U guys r fast!
deckcard
According to what I found online, backup and restore works the same
http://www.ifonetips.com/how-to/transfer-whatsapp-iphone-android.html#part1
muddle
Wazzap migrator and iphone backup browser
Extract chatstorage.sqlite and transfer before importing through wazzap. Can even transfer the media files but I only partially succeeded in doing that. Can get the messages is enough for me.
Transferring from android to iPhone is a bigger mess than this.
Stripy
Anyone has any idea what does the M1 gift box contain for the online purchase of mate 10 pro?
Sent from LGE LG-H990 using GAGT
Well, given you get an SP and back case in the box, the other add-ons like power banks and cables (HN & BD - which certainly don't total the $$ claimed if sourced separately) hardly seem worth waiting for, you probably have them already. The best item was the smart flip case on Lazada, but even that seems to have been taken down now. Another week and the street sellers will offer the discounted price and you can buy 'gifts' of your choice with the difference.
tkpride
Some thoughts after using mate 10 for 4 days:
- screen contrast is really not bad for a lcd screen. No problem with the auto brightness, it seems to know what it's doing
- hand grip and form factor is good, despite it being 16:9. One handed usage poses no problem for me. Better than my moto z play, despite the bigger screen
- battery life is kind of a bag of mixed feelings for me. Could be due to the new phone euphoria. Or maybe I'm spoilt by z play. Hit or miss: sometimes 6+ SOT, max I reached is about 8 SOT. FhD or wqhd resolution doesn't seem to make a difference.
- software : first time using emui. Not too bad. I like some of their power features and the fingerprint sensor navigation. However, it still seems quite buggy. The swipe gesture on the fp sensor will fail to work completely sometimes.
