Huawei Mate 10
raintr33
super super tempted by the flat screen, just imagine how easy it would be to get screen protectors, anyone gaming aggressive on this set can share their experiences?
Sent from 1+3T using GAGT
For my Mate 10 tempered glass protector, the 4 sides are showing a 0.5cm border which the seller says it's due to screen not flat at the edge.
The original screen protector didn't have this issue. Anyone has similar issue?
harky
LOL the phone is ex...
What's in the Huawei Premium Pack for Starhub online promo for Mate10? My contract ending soon,don't feel like getting 2 years contract, so expensive...
I don't know if should redeem the $110 off and buy from qoo10 or wait for sitex... 😥
shager
The original screen protector is not tempered glass.
The screen at the edges are slightly curved so unless you get the full edged protector you will see the usual air bubble border. I couldn't use the full protector as my rugged armor is too tight and pries the glass off.
muddle
Just to share some observation with respect to the supplied ac charger. Plugging the supplied cable results in super charging mode. Plugging the original v20 cable only shows fast charging. Plugging the original belkin usbc 3 cable also shows fast charging only.
raintr33
Good to know the seller isn't pulling a fast one on me. He sounded quite sincere and even offered to give me a upgrade price when his stock of full body screen protection arrive next week.
Should be quite likely to upgrade as the air bubble too obvious.
5408854088
Any issues with Mate 10 Pro OLED display? Any burn-in or colour tint issues that surfaced on other phones?
micshang
Hi, can share the seller for full body screen protector? Like to get for 10Pro. Thank you.
NotsoGoodMan
How to tell if it is in fast charging or super charging mode?
symbiote28
Yes me. I've changed to two screen protector in the span of 3 days and there's this white visible border.
raintr33
I did mine at Changi City Point, the stall is on L2 in front of the escalator beside Singtel shop.
Not sure if they have the pro version yet.
K|muRa^84
Read online that huawei released a software update to fix the batt drain caused by Google Play
Owners, did the update help?
kopi22
I think it's a common problem with all Android devices. I toggle between iOS and Android devices frequently, and notices that it is very common for Android devices to lose massive amount of battery overnight. I suspect the culprit being background apps that are still running. Although you don't see them in the task manager, I am sure there are rogue apps that secretly runs. For iOS devices, I don't see such a problem unless the battery is very old. Even this 2 plus years old iPhone 6S I am using still holds out very well overnight, I.e. On an average, I observed only 1 to 3% battery lost overnight.
Might not be rogue apps. I guess even Android system services can be sucking up the battery too.
shager
anyone have issues with the Toggle app on Huawei Mate 10? I can't play the videos.. keeps saying resume or restart and goes into a loop.
have to force stop the app.
