Huawei Mate 20
Guy84
If any users wants to check which OLED display (BOE or LG) your Mate20 Pro is using, can download this Device Info HW app from Play Store: https://play.google.com/store/apps/details?id=ru.andr7e.deviceinfohw&hl=en
BOE:
LG:
Is it 8GB use OBE while 6GB use LG?
:s12:
amazingone
There's two types of in-display fingerprint sensor, one is optical and another is ultrasound.
Optical in-display fingerprint is the more common solution for phones now, and the Mate 20 Pro uses such technology.
Whereas for ultrasound in-display fingerprint, it is an even advanced technology where it can recognise even when the finger is wet or stained. Currently there's no phones in the market using such technology, though the Galaxy S10 series may be the first to launch it.
Optical is a cheaper solution as compared to ultrasound, that's why optical is still more preferred by phone makers.
Posted from PCWX using SONY SUMIRE
amazingone
:s12:
That's hard to say, because Huawei may mix both BOE and LG display panels together in different batches, irregardless of 6GB or 8GB RAM.
ShadowSin85
Screen bleed issue is real
Does not have it last few days
Now starting to get it
Lol perhap is the glue inside.
deckcard
I'm pretty sure mate 20 pro uses ultrasonic fingerprint sensor. If optical, any medium in between the sensor and finger should distort the image? Personally, I'm also confused and haven't found a reliable source that confirms it. Check this vid
https://youtu.be/l_TFTQuq80k
Tuakong
How do I customise the stock launcher?
Was using nova on my android phones but now decided to use stock
I wanna change icon n screen layout as well as app drawer
athenodorus
can I check if the face recognition tech is the same for both the pro and non pro ?
Of cos not, otherwise why would the pro have a bigger notch if it’s the same?
The pro has sensors that enables 3D face unlock.
athenodorus
Playstore have a few emui theme apps. Can change icons and fonts etc.
There’s already an option in setting to enable app drawer if u want?
petricnah
Hi, anyone using Nova Launcher (paid verison) with the unread count still working? My does not display since ytd, I figure out what's wrong.
jackycar
Yup I stopped using Nova cause tesla unread wasn't working. Huawei default launcher emui got unread counter for Whatsapp built in alr
1982-1994
I'm gonna miss the swipe from edge to access common contacts for call though...and samsung pay benefits. that's about it :s13:
does huawei cloud backup work in singapore? my friend says it only works in china :(
Haven't tried using the integrated cloud services, yet.
Haven't redeemed Samsung pay benefits too lol
deckcard
Hmm weird, mine is actually working. Did you use the latest version of niva and Tesla?
amazingone
I'm also a little confused, but all that info I got from Weibo. The tech bloggers there mentioned that the phones now that comes with in-display fingerprint uses optical(光学屏幕指纹), and the Galaxy S10 series will be the first to use ultrasound(超声波屏幕指纹).
