Huawei Mate 20
petricnah
Yup I stopped using Nova cause tesla unread wasn't working. Huawei default launcher emui got unread counter for Whatsapp built in alr
My was still working until Thur or Fri, Sian arh..., I find it difficult to manage notifications. Have to pull down the notifications bar to check.
lorettatay
How to enable emui launcher to have drawer for apps?
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
ayuluv
BTW besides red white, is there anywhere doing loca full adhesive for m20p?
rain_myth
no sia, i read up on some chinese huawei forum on baidu, tens of thousands of people are affected by this screen bleed. And it seems to be spreading
tens of thousands of ppl? :s13:
bor statistic back up is empty tok lah
wat i read is mostly a grp of hongkies kpkb on these.
Tuakong
How to increase the icons on the dock?
Current I hv 5 icons but I wanna increase to 6
deckcard
I'm also a little confused, but all that info I got from Weibo. The tech bloggers there mentioned that the phones now that comes with in-display fingerprint uses optical(光学屏幕指纹), and the Galaxy S10 series will be the first to use ultrasound(超声波屏幕指纹).
Posted from PCWX using SONY SUMIRE
I'm waiting for some teardown of mate 20 pro and that should confirms optical or ultrasonic sensor
deckcard
I've disabled display carrier name and changed the notification to numbered instead of icons so I get more space and it display numbers on the notification bar so I can tell if new notifications.
You may want to clear data on Tesla and see if it helps.. worst case uninstall Tesla and reinstall again. Also go into Tesla and setup what you want it to display. In Nova setting, you can also choose numbered or just dot for notification
petricnah
Clear data, and it is working now. Thks.
wjx1996
I think if it's only minority of sets getting this issue. HW will not even have acknowledge the issue. Probably quite a lot affected.
Sent from Samsung SM-N960F using GAGT
hopefully it's minority. If majority maybe will kena callback
bellick
Tbh note 9 would be a good option instead of the m20
Yup gotta agree with you. Note 9 can be purchased for around 900+ now, while mate 20 and OnePlus 6t are also around the same price range.
Note 9 is probably the best all rounder in terms of hardware, with hardly any compromises?
plsdunbiteme
My quick thoughts about the phone which I have got for about 3 days.I also have HTC U11+ so can compare a bit.
The good:
-Fantastic screen (no bleeding issues for me), much brighter and more vibrant than htc
-Nice size and form factor for me
-Camera is fun to use and versatile but I still think my HTC takes better shots
-Blazing fast performance for everyday use, comparable to HTC
-Very fast face ID
-Runs very very cool, even when fast charging. HTC gets hot much faster
-And the best thing: Crazy crazy good battery life, much better than HTC
The not so good:
-Don't mind the notch per se but because of it there is very little space for notifications - have to keep pulling down notification shade to check
-Speakers so so only
-Sound from dongle+earphones very average
-Mic recording quality from videos also so so
(in all above 3 aspects of sound, HTC U11+ noticeably better)
-When connected to Bluetooth in the car, there is lag in audio, when playing videos. Also, once connected Bluetooth, it will insist on autoplaying from music app which is very annoying
-FFC a bit soft on details
Overall a very good and feature packed phone.
Gondon72
what if u try turning off the notch? does it work?
or go to the settings and turn off the full screen mode of that particular app.. might also work
Still the same...in the end have to download an app to remove the status bar during gaming..lolx
