Huawei Mate 20
MisterU's
Hi, has anyone had their dual sim issue resolved? I couldn't make calls, only receive calls and send/receive sms on SIM 1 if SIM 2 is inserted. Even if I set SIM 2 to inactive the same thing happens. The only way that everything will work on SIM 1 is to physically remove SIM 2. I inserted both SIMs on another dual sim phone and both worked fine. Thanks.
Sent from HUAWEI Mate 20 Pro using GAGT
softlink
Mine is LG-01-18-10-51 batch. No green tint at all. Hopefully stays that way. From what they say.. This current batch might be LG screen too? That's why they are testing. Then 2 weeks later batch is BOE screen?
Actually anyone with the issue can ask CSO if it is really LG screens only affected?
jackycar
Just had my full adhesive tempered glass done at Xgear at waterway point.
Damn good! no issue with fingerprint at all. Can fit my spigen rugged armor case perfectly and no popping also
As usual their application service is so professional they took almost 15 min to make sure its applied properly and perfectly. Love it man.
Highly recommended for those who are looking for tempered glass with the spigen case
The tempered glass is really smooth and feels pretty high-quality as well unlike those cheap ones that feel a bit rough and too much friction
Also, I'm having less issue with fingerprint on this than with the film protector which was already very good. Film I would fail maybe 1% or 2% of the time, this one is perfect every attempt so far.
softlink
Oh thought theirs was film type. Is their tempered glass UV type? Any black borders?
Abyssal.Xuan
Bro how much is the TG? Thanks!
jackycar
Yup I did my film with them also. Not sure if uv but yes I think got black borders but it's sizing is done really really well
Cause if it can fit the spigen rugged armor I'm sure a lot of cases can fit
zimmy83
Wow that's a nice gesture from Huawei, give a free Huawei powerbank to affected Mate20 Pro users.
thanks awesome. i tried messaging HW but didnt get a response from them, im using the Mate 20 Pro so not sure if this will be officially comms to everyone. I called the service center hotline but i was not even given this form of reassurance.
Geros_Peters
Mine is batch 51 too and LG display. Hopefully it stays problem free for mine too.
That's good to know! Now we have more options using different cases and not affecting the tempered glass protector
Geros_Peters
Now huawei should be swamped with all these feedbacks, so they might take awhile to give you a response.
ayuluv
It's better to let them contact. You
ayuluv
Good for you mate!
Red white also have a very good service for loca tp.took sometime for the uv to let the glue settle down but good job
jackycar
Good for you mate!
Cool! I heard the Loca one doesn't fit spigen rugged armor tho? So I couldn't do.. :(
athenodorus
Why don't change case instead? A full adhesive tempered glass is more worth it to have rather than a case. Case can find others to try.
kyleongwl
Want protection and clear back(rugged armor defeat purpose) to show twilight or green mah.
I uses the Huawei silicon with a good TG (FP working).
jackycar
I already have a full adhesive TG that works my case! Spigen rugged armor isn't as bulky as UAG and offers full protection
