Huawei Mate 20
Auggie246
Bought Dome 3D full curved tempered glass in westmall kitty mobile, at $59.90, included installation. Not bad, compatible with the original Huawei case. Fingerprint scan works.
Smlj 59.90 screen protector? Made from crystal ah?.....
wrathbringer27
Why not if you're able to. If it's not urgent to change then wait lor. I would hv done that if my v20 could run PUBG smoothly lol. If p30 pro is gonna be a major upgrade to the mate 20 Pro I might sell the M20P for the P30P
lol.. me too! now that Huawei has responded (although not officially to the press), it seems that the problem will be gone in a couple weeks' time.
but just wondering if should just wait for p30 pro... in March? hmm.
molecule
Anyone using the casing and screen protector that comes with the phone? ;) Quite cool to package them w the fone, provided one uses it haha.
zizagged
Just to share. For my m20pro, I got uag plasma case from p2o mobile can use together with the full adhesive tempered glass from red white mobile. Uag case this time round has 1mm top and bottom clearance and doesnt push up the tempered glass.
Will monitor for a few days and update here.
How much is the Redwhitemobile tempered glass?
Sent from HUAWEI LYA-L29 using GAGT
Lobaba
my 1st day at work with huawei mate 20 yesterday and was very pleased with battery life. With sync on and long SOT, I think it was around 5~6 hrs, i lost only 50% battery life after 12 hours.
Lost 2% battery life after 1 night of sleep!
cottoncloud123
What do u disable in the night when u are asleep? I'm using mate 20 non pro too and every night i lost about 5% with approx 8 hrs of sleep. Is this normal?
jackycar
I still wonder how ppl get such good SOT and remaining battery life. I also clock about 5 to 6 hrs SOT, but end the day with about 20%+ only.
Under Battery consumption it shows my usage is 19hrs tho. It means a lot of apps are taking background cycles?
I've already Manually set app launch to untick all apps except Messaging ones. Anything else I can do? Uninstall apps?
Gondon72
Accidentally press the wrong language for HiCare apps. Does anyone knows how to reselect to english again?:(
1982-1994
With messaging apps like WhatsApp,etc running in the background?
