Huawei Mate 20
lorettatay
Want protection and clear back(rugged armor defeat purpose) to show twilight or green mah.
I uses the Huawei silicon with a good TG (FP working).
Ya mine is green also wanted to get a good clear case
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
sgbsgb
Just to share. For my m20pro, I got uag plasma case from p2o mobile can use together with the full adhesive tempered glass from red white mobile. Uag case this time round has 1mm top and bottom clearance and doesnt push up the tempered glass.
Will monitor for a few days and update here.
Hope to hear good news from you after few days. i went down red white yday and was told the TG is not compatible with UAG case hence i din bought it.
techizen2
Hi, has anyone had their dual sim issue resolved? I couldn't make calls, only receive calls and send/receive sms on SIM 1 if SIM 2 is inserted. Even if I set SIM 2 to inactive the same thing happens. The only way that everything will work on SIM 1 is to physically remove SIM 2. I inserted both SIMs on another dual sim phone and both worked fine. Thanks.
Sent from HUAWEI Mate 20 Pro using GAGT
Did you use Phone Clone to transfer your files? If yes, it may have transferred your old phone system files also and messed up your new phone system.
I have exactly the same problem as you on my M20P but after factory reset, both SIMs working fine now.
MisterU's
Set it up from scratch, didn't use the clone feature. Let me try another factory reset, 1st one was due to a play store issue. Hope it doesn't spawn any new problem after. Thanks
Geros_Peters
I just went down today to show them and they were surprised too! Usually UAG cases are one of the most tight fitting in the market and this time round uag made it less tight fitting. I was pleasantly surprised as well.
sgbsgb
Shall wait on yr news update after few days. Will make a trip down again if everything turn out fine. Thank you for your info.
Retrospect18
wah this is quite serious. Hope you cab get 1 for 1 exchanged
They offered me a 1 to 1 exchange after they have monitored the new phone, or ask me to wait for the new stocks coming in which they guarantee will have no screen issue.. I chose to wait. They replied me at 1.30am last night after I msg them, really appreciate it.. Good cs!
Sent from Huawei MATE 20 PRO using GAGT
TheCaffeEspresso
Anyone know mate 20 not pro will have the 3D scanning soft you features?
Sent from HUAWEI Mate 20 Blue using GAGT
abhishek.agger
When is the new stock going to come? I mean the ones which they guarantee will not have display issues.
Retrospect18
About 2 weeks, and they also threw in a small gift as compensation..
Really happy with their after sales service so far..
Retrospect18
seems like no issue stock is coming...tempted again :crazy:
Apart from the screen issue, this phone had been the best I have used so far.. From P9, P10, Iphones and Note 8.. Super fast and camera is spectacular..
s-ghost
High Honorary Member
the only thing I hate is the curved screen, otherwise would have bought it in a blink
meteorite
Bought Dome 3D full curved tempered glass in westmall kitty mobile, at $59.90, included installation. Not bad, compatible with the original Huawei case. Fingerprint scan works.
GReddy G9 RS
May i know how to tell is it local set or from other country if i buy direct?
Sent from HUAWEI MHA-L29 using GAGT
maumu
lol.. me too! now that Huawei has responded (although not officially to the press), it seems that the problem will be gone in a couple weeks' time.
but just wondering if should just wait for p30 pro... in March? hmm.
