Huawei Mate 20
JayBeeLwashere
May i know how to solve an issue when all my downloads are pending in the play store? Tried uninstalling the app store and clear cache and all my updates/new apps are all stuck at pending download
flyingeagles
Clear data and cache for Google play service And Google play store
Sent from HUAWEI LYA-L29 using GAGT
AcEz874
I not given any powerbank or any free gift during exchange and I didnt bothered to ask for it.
My right shadow is really distracting the more I use. I may drop by HW to ask again.
Took some photos, with top half being sky n white background, then the right shadow just keep distracting me. The left is OK, really a faint tint which doesnt distract.
Hi bro can you take a picture of it? Im curious about the shadow, i myself is using the LG panel since 13 November and i want to know what the problem.
funtasy
Buying Huawei Mate 20 Pro from Hong Kong
Hi. Not sure if this has been discussed before. Is the Huawei Mate 20 Pro without a line, cheaper in Hong Kong and also if I buy the phone there, will I be able to use it back in Singapore? Thanks!
Fattytotti
My Mate 20 X brought from changi Airport only showing 12 months warranty. Mate 20 x only come with 1 year warranty?
aallzz
Can buy there but warranty only HK. Not sure if its cheaper.
siaoz85
Guys, I thought most ppl here who went with Red White Mobile loca glue tempered glass have no issues with fingerprint sensor. But for me, it was wrong most of the time. Even after I re register my fingerprints, it was abit hard to register. Any idea what's wrong? But the feel of tempered glass and its sensitive is perfect. Only fingerprint can't use at all
zacky1223
mine sometimes cannot register than i double tap to use faceunlock. Same for the other way round. I am ok with it. :)
My tp is from rwm. So far I like it.
batniss
Incompatible due to thickness/coating/whathaveugot. i tried quite a number of SP before finally found one that actually works with Finger-ID. Those "incompatible" function perfectly except... fingerID
zackzz
does anyone faced fast battery drain issue on m20p?
r u referring to standby drain or usage drain? I do encountered overnight standby drain sometime back.. 16-20% eventually resolved its caused by the wifi mesh given by singtel ,for usage drain have no issued
ayuluv
thanks mate. I am referring to the usage drain. It seems that it drains faster and faster day by day when i play some games on it
aallzz
I had the same issue. i went back and they re-applied for free
siaoz85
Can you share what did you buy which works with the fingerprint?
