Huawei Mate 20
James Tang
Like to ask those who have applied the loca glue tempered glass, does your glue still leak to the sides after the installation? Needs further time to cure before putting on the case?
Sent from Samsung SM-N950F using GAGT
Yes. better leave it for a longer time. Once done, wipe off the leaked part cause dust will stick to it and looks kind of ugly (to me, irritating haha)
savior1
Yes the Huawei cases not compatible. UAG cases they say its OK. I used clearvue from Xdoria for about two weeks. no problems with SP. Xdoria bought at Mobilestop at NEX
Actually I just bought at RW the tempered glass protector last night and it's compatible with the default HW case. They applied it and put on case for me also. Yes it's $30
athenodorus
Yes it can work with stock case.they just dun want to promise it will work cause ultimately its about heng suay one. Some works some doesn't. So they rather play safe.
Same goes to other places that does the installations.
aallzz
I would not recommend that. The firsg time I also used the default HW case, but after a week plus the edges show signs damages and not mucb later SP popped up. That is because the case is flexible
cioelim
Need some opinions.
Understand that HW is selling supercharge powerbank 10000mAh and 20000mAh at the same price $98 via their authorised retailer at Lazada.
Which is recommended to get?
bystander1965
Need some opinions.
If you travel by plane, I believe by right the 20000mAh one exceeds airlines' limit for power banks.
Power banks cannot be checked in and can be carried in the cabin if it's below 160Wh. This HW has a 9V output. So it's 180Wh. But I am not sure if they really check.
Often times they just verbally asked me if I had one in check-in. I occasionally had one in the carry-on and would indicate so but they never looked into it.
cioelim
Is anyone still going to HW doing the exchange? Are they still giving the powerbank when u do the exchange? I'm having the side border with slight green screen problem when on white background, and thinking if should go down to do the exchange.. any views? :o:D
savior1
Yep I guess with every case there is risk. But it was the staff there that told me confirm can use with default case. Asked 2 of them. So to each his own I guess.
kaysee
Just bought my mate 20 transparent casing and full glue tempered glass done up by mobilelite. Their quality is always good so for those still looking out can just check his facebook or carousell.
aallzz
what kind of transparent case is it?
Member2020
You may go down to service centre to register your case and await for their sms to come again some other day for exchange when stock is available.
kirium76
Anyone managed to try out the 3d scanning successfully? I tried many times but failed miserably. And the phone gets hot when using this app!
Sent from HUAWEI LYA-L29 using GAGT
sajokj
Don't waste time on this, it won't work as expected.
maur_james
I did, once. You need to do it in a brightly lit area, if not the item scanned will have different brightness and shadow, not evenly exposed. Phone need to maintain at least 15cm away.
striker22
Anyone here converted from iOS and is a heavy user of Notes?
I am finding that Huawei notepad is too basic and also doesn’t offer much options for formatting and also I cannot lock notes individually. Previously on Apple, I could lock selected notes that I use to store confidential information.
Huawei only allows me to lock up the entire app.
kirium76
Yes agree that the type of files that can go into the safe is very limited lo. Locking the app is the only way for now.
1982-1994
Hi mate are you referring to the navigation gesture?
Yup I am using "no button" style
Download and install naptime apk
You have to adb it by connecting your phone to your PC.
By default, our phones would get into doze mode only like after an hour or so. But with naptime, it can be as fast as a minute. Try it.
