Huawei Mate 20
aallzz
Yes the Huawei cases not compatible. UAG cases they say its OK. I used clearvue from Xdoria for about two weeks. no problems with SP. Xdoria bought at Mobilestop at NEX
But RW one only compatible with uag? The default case can't fit right?
Sent from Samsung SM-N950F using GAGT
kirium76
Ok. This RW is $30?
siaoz85
mine sometimes cannot register than i double tap to use faceunlock. Same for the other way round. I am ok with it. :)
My tp is from rwm. So far I like it.
I'm OK to unlock using face. But for certain apps like bank apps, will still need fingerprint.
1982-1994
thanks mate. I am referring to the usage drain. It seems that it drains faster and faster day by day when i play some games on it
You using immersive gesture? Meaning the gesture like iPhone x
cioelim
Anyone switched from iphone to m20p? Can advice how to transfer WA char history? Tried many methods found online, paid ones also, but not successful.
winningeleven
Wanted to recontract soon under m1 my sim plan at $70.
M20P at $468
M20X at $468 but with come leather case and M-pen.
Using xiaomi max now. I like the size of M20X but then I find it is much worth to get the pro version since the retail price of the pro is much higher at $1348 compared to X version at $1148.
Which one would u take?
aallzz
Depends on your usage.. for everyday phone i think M20P best.
M20P at $468
winningeleven
Of coz phone is always with me to use everyday. I am not into any gaming but then i got lao hua. so i need a big phone. That is the only thing i like about M20X.The M20P look kinda small for me. I compared my mi max with M20X. Both phones are same size physically. Mi max is 6.4 with top and bottom bezel where M20X with almost no bezel.
I always wanted a smartphone with IP68 rating so that my phone is still alright even i worked in the rain. Somemore i like to travel. The better camera is also a plus point
dannytan5996
This. I bit uag plasma w kind of jap sp. Was told m20x -no casing. M20 available on certain country still have
kirium76
Like to ask those who have applied the loca glue tempered glass, does your glue still leak to the sides after the installation? Needs further time to cure before putting on the case?
TheCaffeEspresso
Anyone have any idea if the fast charging cable for mate 20 is it same as mate 9 ones?
Cause I have a spare cable from mate 9.
Sent from HUAWEI Mate 20 Blue using GAGT
James Tang
anyone feeling disappointed with the camera? i went to a concert yesterday and the pictures i took using pro mode, man it sucks. was using the x3 zoom and the quality is just terrible. i've shot better using my mate 9 and mate 10.
I do not know the level of your understanding on various settings under the pro mode. Pro mode is not for everyone, you need to know how each of the parameters are before using pro mode. So on this part, I cannot comment.
There's always a misconception that using the 'best' camera automatically will make one a good photographer.
But most of the time, for non photographers, one just use auto with AI on.
