Huawei Mate 20
Blueberrytea
just gotten my mate 20 pro for $118,
wanna check, does your phone get very hot when charging?
i'm using the wireless charging mode
When using wired fast charging it does get slightly hot...wireless unsure as I do not own 1
Abyssal.Xuan
If that is your argue point for covering up for your
Go play store search for play store then go ahead .
Most handsome man in the world HardwareZone Forums app
Sorry I don't even know why I'm getting involved but I'm curious. Where did he say to go playstore and search for playstore?
The fella only said "Search Google play store APK?" Right :s13:
Which I think is similar to what you said: "Search Google for how to install Google play store ."
Except you used "for" which makes it easier to understand. Other than that, no where does he recommend to search the PLAYSTORE for playstore
Nothing against you man, and if I'm wrong tell me, I'll apologise!
chenaz
After my initial post the he changed to the correct one.
the stock swift keyboard is a flop..
i just change it after a day use:D
I find it okay. Spacious to type.
Didn't like it initially last time as it did not support Chinese characters then.
Was using Google pinyin previously.
chenaz
Use mobile phone app to edit lor. If u suspect I accuse him then go ahead. So long already .
Edit via mobile phone
He deleted and re-posted? Because i don't see the "last edited" text from his original post!
I'm not defending him or anything, just want to find out!
Swiftyz
Have anyone tried using mate 20 pro with the galaxy watch active? How's the pairing and usage?
batniss
Not sure what u meant for $118, is that to brag or?
Because $118 is with some high value plan right, if so u have to state it otherwise u should not state 118 at all
Really misleading and totally no idea of the intension.
If u got the set at 118 with no contract, let me know where to get it. Thanks.
Abyssal.Xuan
LOL if you cannot read and say I accuse you then go ahead
:s13:
I really was curious! And, thanks for highlighting the mobile edit part. That's new to me!
I'll stop here hahaha. Have a good weekend!
Edit: giving the benefit of doubt, then I owe you an apology too! Sorry!
