Huawei Mate 20
sajokj
Does anyone have issue with their mate 20 pro vibrating randomly? Mine does that and force stopping the download manager or clearing cache doesn't help. Thanks!
Yes. With out any notification, Phone Just vibrate.
friedapple
Gosh is this due to a bug from their update or? I cant seem to get rid of it. Any advice would be greatly appreciated!
ApPle5
Same for my Mate 20. Keep thinking it's a notification but nothing.
Sent from HUAWEI HMA-L29 using GAGT
mun_hoe
wanna ask, there are random times that my mate 20 pro and it's bundled huawei fast wireless charger dun charge at the instance I placed my phone on the wireless pad. even by direct wire charging. wall plug charger and cable are all huawei's. but a power off switch off and wait out 10 seconds will get the whole wireless charging to work again.
anyone here have this random issue?
aa123aa123aa
try installing apps like "Notification History" from play store and see what's the app that's sending notifications that are not shown
Sent from HUAWEI LYA-L29 using GAGT
Gadgetfreakloh
I have this issue when i am do charging when i place the wireless charger near a metal place or near some electrical devices. I think the charger have a field safety check feature. Just move it away from those interference and try again.
mun_hoe
no doubt it is near a usb powered desk lamp. thanks for the suggestion
inviztj
Does anyone have issues with the notifications? For example, when I have an unopened Whatsapp message, when a new message comes in, the old message will be shown in the notification instead. Same goes for Instagram chat notifications. Instagram also has another issue that after opening and reading a new message, after a while, I will receive a duplicate notification of the same chat.
DeMisE
I suddenly got one green line along my screen today while just charging my phone, when i picked it up then the green line appeared.
I previously got the green tint issue already, so is my phone still under warranty if I go down Huawei Service center and request an exchange? Current screen is BOE
jEpnah7
Similar to this
friedapple
jEpnah7
Similar to this
Looks bad I think even if your screen 3mth warranty is over, you should still insist for replacement as this is clearly a widely reported defect.
Please keep us posted.
vasilli07
jEpnah7
Similar to this
Got this issue on my 2nd day.
