Huawei Mate 20
mahcosg
love my mate 20 pro, the notch add characteristics to the phone. fast charging ease the inconvenience of carrying a battery bank. bezel free screen is a beauty to behold.
r0_ger
My wife got the film for her Mate 20 Pro (Im still using P20 Pro, but reading here to update her, if she encounter any issues with her phone).
the film she got wraps to the back of the phone, so no issue on the curve edges.
What film is that? How is it so far? What kind of SP should I avoid if I am using Spigen Rugged Armour case?
mds8080
Anyone using the mate 20 pro find that the usb c earpiece (supplied one) will auto disconnect after a few seconds if there is no music/sound playing? I have to remove and reconnect it to use the earpiece again, very irritating.
I found that using other normal 3.5mm earphones + usb c adapter doesn't have this disconnecting problem.
Any solution? My phone is only about 1 month old.
ZergRush
What browsers are you all using? I'm trying brave now. But recalling the bookmarks are quite troublesome
kryptonit3
go service centre request replacement for USB c adapter?
ApPle5
Anyone used this kind of case before for Mate 20? Wonder if any good.
Also anyone got recommendations for matte screen protector for Mate 20? I'm using the default one that comes with the phone, find it too reflective...
Sent from HUAWEI HMA-L29 using GAGT
mds8080
No what I meant is that the supplied usb-c earphones got disconnecting problem.
No issue with the usb c adapter with normal earphones.
No one else encountered this issue? I did search online and seems like others also encountered
htngwilliam
Looks thick. One issue is if there is a gap between the front glass and glass protector, likely the touch screen feel won't be great
stupidog
this type once u drop it , it will split like a banana :s22:
Audiology93
I'm using Matte TG on my Mate 20. Bought from taobao for roughly $7 for 2 pieces including shipping.
Sent from LG G7 ThinQ using GAGT
ApPle5
Looks good. Can sic link? I have no idea what is the Chinese word for matte
Jlyong0008
if u have high expectations of the cam then go with the p30 pro and don't compromise. my personal take of the mate 20 cam is it still wins most other cams out there, and considering price vs features, it's a steal.
Agreed that the vanilla Mate 20 (non-pro) is a bargain among flagships and some compromises have been made, perhaps in the camera department.
I just find that the image processing is a little weird and not true to life. Sometimes, facial complexion become quite splotchy and results looks funny. I had to disable a lot of Huawei’s image beautification and DON’T ENABLE VIVID MODE.
But yes, sometimes the images rendered can be sharp as hell.
I’m also quite impressed by the video stablization. It may only be electronic but WOW. I used it to capture children at play and it was ridiculously stable.
Audiology93
【华为mate20钢化膜mate20X手机膜mate10磨砂蓝光mate10pro全屏覆盖防指纹防摔半高清无白边玻璃贴膜游戏防手汗】https://m.tb.cn/h.eXKQPXv?sm=aca54c 点击链接,再选择浏览器咑閞;或復|制这段描述¥gqBYY1jRtZT¥后到�淘♂寳♀�
Which case are you using? Looks good.
The free case that comes in the box lol
Sent from HUAWEI Mate 20 using GAGT
ccmheoa
I'm using a 8gb / 256GB mate 20 x
While I havent really tested the screen on time, so far I haven't been able to exhaust the battery within a day, usually left 40 percent or more at the end of the day with heavy usage
Gsmarena Says 15 hours of web browsing or
18 hours of looping video playback
https://m.gsmarena.com/huawei_mate_20_x-review-1882p3.php
I don't think Mate 20X can get 16hrs SOT. Anyone with Mate 20X can verify?
Sent from HUAWEI MATE 20 using GAGT
