Huawei Mate 20
chenaz
Hi , I using Mate 20 pro and I used for driving grab . The phone GPS is not very accurate awhile using 9.1 and 10.1 . I already replaced new motherboard and I tried to calibrated my gps and it still not working . Anyone face the same issue as me ? I asked some driver he Iian using mate 20 pro , he mentioned that so far no issue and the phone is very good . I not sure what is wrong anyone can advise and help me on the phone ??
What do you meant by not accurate ?
Gps is never accurate .
But using Google direction should be too far off.
friedapple
My mate20oro warranty also expiring this month. Planning to get battery replaced too. So how did you proceed with the battery replacement? Did you just say you want battery replaced? Or did you have to say you are experiencing bad battery life before they agree to replace?
Posted from PCWX using LYA-L29
Just tell them that your phone's battery life is very poor. When during warranty they will replace it without much or any questions. Quite common I would say.
friedapple
now that warranty for my m20pro is over, what phone should i change to?
anything but huawei LOL. huawei mate 20 pro will be my last phone with them, i have not forgotten how they changed my lock screen to booking.com. Totally no security at all.
ApPle5
I'm using mate 20, used to be able to listen to radio and play game at same time. If there is ad with sound, I can still listen to radio. But I forgot after which update, now if listening to radio and there is an ad, my radio stops. Can only listen to 1 at a time. Any way to fix this?
Sent from warm cockles of my heart using GAGT
andyhtc
Suspended
My battery drains very fast recently. I attribute it to the Trace Together app that I installed and turned on about a month ago. With deeper battery discharge and more frequent charging, my battery will wear out faster. I will have to change it around March 2021 before my warranty expires in April 2021.
GReddy G9 RS
No more update for mate 20 series? I'm still stuck at oct security patch.
Sent from HUAWEI LYA-L29 using GAGT
singexpat
Thinking to change to xiaomi next year if there are still no Google svcs. Hopefully Biden will remove the stupid sanctions.
fishnchips
If cant find the invoice for the phone, the warranty will be based on the s/n of the phone registered in the system? is it the same info found online when one input the s/n of the phone ?
dragonhole
If cant find the invoice for the phone, the warranty will be based on the s/n of the 7phone registered in the system? is it the same info found online when one input the s/n of the phone ?
They didn't ask for physical invoice when I went for servicing. Should be based on my registration in support app.
andyhtc
Suspended
Next year, my main problem with Huawei flagship phone is the price rather than the OS, which looks good from the article below. Its latest phones are getting very expensive compared to just 3-4 years ago...
Huawei HarmonyOS 2.0 “super devices” pave way for future without Google
https://www.slashgear.com/huawei-ha...-pave-way-for-future-without-google-16651394/
OutBreak
Indeed, Huawei is getting more and more expensive. I am thinking of switching to Xiaomi or Poco. :(
Kunkka
my hisuite got problem cant restore password vault after i repaired the motherboard
any way to access the info inside?
