Huawei Mate 20
zacky1223
Hi guys can i check are you all experiencing lag on your mate 20 Pro? Sometimes when I search for app in the search bar for example I type a those apps only appear in awhile. The whole phone feels sluggish. I am on emui 10.1.0.
Skagen
just stick to the original firmware and you're guaranteed the phone won't feel lag as long as the battery can last:s12:
andyhtc
Suspended
Mine is okay. The speed is as fast the day I bought it.
I intend to go to the Somerset service centre to change my battery so that it can last me another 1 year+. Thereafter, I will probably switch to Mate 40 Pro or P40 Pro as I don't depend so much on GMS - usually I access via Google website links.
Xiaomi flagship handphones always seem to have some issues and they are no longer cheap too.
andyhtc
Suspended
P30/P30 pro is the last. not 20
Yes, I mixed up the Huawei numbers as my attention has now changed to Xiaomi. I'm still deciding between Huawei and Xiaomi as my next phone after this Mate 20 Pro next year.
andyhtc
Suspended
Guys,is p20 pro still worth getting now?
I recall P20 Pro was launched in Mar 2018, so it is already 3 years old. Likely there is no more warranty left for the 2nd hand units and the battery would have been quite worn out. The 2021 mid-range Xiaomi and other brands should be able to meet or go beyond the specifications of P20 Pro. Remember to get global sets as China ROM may result in Google issues like Huawei later.
Huaweige
Why not p30 Pro with Google Services? I'm thinking of switching to p30 Pro when mate 20 spoilt as I loved Huawei battery life compared to Samsung note.
I did thought of p30 pro but i prefer flat screen display and im using mate 20 at the moment so choices are pretty limited.But i have to agreed with u,huawei battery life is really good
Huaweige
Yup totally true.xiaomi is 1 of my favourite brand too.thanks for your input bro.appreciated.
andyhtc
Suspended
Recently, Huawei is more determined to use its own Harmony OS and Google also restricts non-Google phones from installing its services. Hence, things will just get tougher if you want Google on Huawei's phone. Xiaomi and other Chinese brands are catching up really fast in terms of specifications and unfortunately, prices too. Huawei still holds a slight advantage on camera though (e.g. 1" sensor coming).
