Huawei Mate 20
Abyssal.Xuan
The staff cannot promise the freebies quantity. But today onwards can put $50 deposit to guarantee your preferred model and colour. Saturday walk in to collect and pay the remaining amount.
Solid, thanks bro!
Now I'm worried HAHAH. Need to go recontract at Telco then can go down and try redeem.. sian
Sent from LGE LG-H990 using GAGT
junjie433
Imho, make no sense if there's no guarantee getting freebies even if you direct purchase from roadshow.
Logically, they should cater 1 batch freebies for roadshow sets and 1 batch for Telco sets..
Of cos, ideally is to have telcos giving out same freebies as roadshow... =]
Sent from Nokia 8250 using GAGT
They shld make it pre-order and collection at causeway point.
algerr
Solid, thanks bro!
Can have 2-man operation.. 1 go Telco..1 q roadshow..
javierlee30
Should make it like sammy pre order got freebies. Or wait for ah beng shop maybe cheaper without the freebies.
Abyssal.Xuan
Unfortunately I solo Kia leh. Shall try to recruit a relative HAHAH. Hopefully can get the freebies ):
Ah... that means next time phone with no headphone jacket will have to switch to bluetooth liao ?
What if I dont want to fried my brain ?
I have a sexpensive headphone ? Go to waste ?
If you not that particular about sound.. a Bluetooth wireless earphone will be suitable for you.
E.g creative outlier one - sgd39
benyee90
Can consider a USB type c dac. I prob get one myself. The dac is small enough to be fitted in the USB type c cable. Amazon has a few and some got good reviews
wa kin cham.... nowadays a simple thing like listening on my sexpensive earphone I have to buy a USB type c dac....
s-ghost
High Honorary Member
just now was trying out a demo set, how to go to home screen from app ah? :s13::s13:
maumu
this review just KO-ed my interest left of the phone... but thanks much for sharing.
"This new in-screen fingerprint scanner is an optical one, rather than the ultrasonic one that Qualcomm is developing. And you can see how the screen of the phone lights up for a second when you tap your finger against it, so that the phone can get a proper, bright scan of the finger...
How does it work? Mostly well, but… it is not quite perfect. We have gotten used to traditional fingerprint scanners that are lightning quick, where you just tap your finger on the fingerprint area and the phone unlocks instantly. In the case of the Mate 20 Pro there are two things that get in the way: the first one is the fact that there is no physical boundary that would give a tactile indication of where the fingerprint scanner lies, so you need to look down at your phone to nail the exact position where your finger needs to be every time; the second thing is the actual force required to get a proper finger scan, as you need to press a lot firmer and longer than the gentle tap required from a traditional fingerprint reader. If you don’t press as hard, the phone will not unlock and you would need to try again.
I shall wait for p30 pro that hopefully comes with ultrasonic in-screen fingerprint. hopefully the weight can go down also and best if they can improve the camera to optical 5x :D
Lol.... sian liao.... but still can use face to unlock ma
