Huawei Mate 9
meekiatah
Went to 313 svc ctr yesterday around 11am. Collected back the phone around 130pm. They change the battery & mother board. Not sure how true did they change the battery as I feel like roughly the same..
Maybe you just changed the battery and spent time restoring data. Hence, used more initially. Have to monitor.
Motherboard? Are you sure motherboard too? Cos usually if change battery, they will change screen too as connected. Unless your phone got serious issue then change motherboard.
Posted from PCWX using MI MAX 3
RSKeisuke
if the imei is different, the motherboard has been changed
lwandyh
Yes they change the mother board cos have issue on the micro SD compartment, sometimes can't be detected. So the person say change motherboard & battery. But never say change screen leh.. but if change screen, can check the different? Will they take off the old screen protector?
meekiatah
I see. Change screen, phone will come back without screen protector. At least, mine did.
wcmonk
hi, any idea where to find the list of changes n news thing from the updated version 9?
Anything_Whatever
andyhtc
Suspended
My Mate 9 is still running very well. After this update, I'm likely to just change my battery and use for another year+
highsulphur
Went to change my battery today before my warranty expires next week. Had to restore everything and upgrade firmware several times. Quite a hassle. Hope it was worth it
sunstarsunset
The Huawei Mate 9 is a phablet that's built to last, with an impressive camera, powerful processor and great battery life.
eyz
Android Q will be releasing this year. if huawei pushes EMUI 10 for mate 9, I'll be fully satisfied.
If not mistaken, Mate 9 series was launched in SGP sometimes on 29th Aug2016... slightly 2.5 years back... so not that old.
