Huawei Mate 9
mafia86
Hi to all those holding Mate 9, when you play music or media, do you have sound coming out from 1 side or both sides of the speakers below? Mine only have sound coming from the right side...
kennyg1969
Speaker only on the right side... the left grill is there for aesthetic look
princewenle
Anyone know how to control the charging for mate 9?
Just checked with the huawei support, they advise to unplug the charging once reach 100%.
My phone always low bat around 11pm and its my sleep time.
Once I wake up, it might have been charged for more than 5 hrs.
Any apps or setting can stop the charging once reach 100%?
Sent from HUAWEI MHA-L29 using GAGT
efini81
My gps location will automatically on by itself.. is there an6 sett8ngs that I missed out?
RSKeisuke
you may have to verify if the information given to you is 100% correct..
i can't believe such a high end device is not built with power management circuitry to monitor charging..
lumpyme
just a quick share, read from here somebody suggested using nova launcher to swipe up to turn screen off
it'll give you 2 options, if you used device administrator finger print unlock will not work anymore
otherwise it'll just turn the screen black and wait for device time out
an alternative is to enable the floating dock from smart assistance inside the system settings
from there you can click on floating dock and choose lock
takes 2 steps to lock your device but finger print unlock still works
kenstyle
Yes but with the floating widget, it makes the phone like an Apple phone. Haha
I would prefer if I press the home button and hold the screen goes off. But couldn't find any options on tt.
Then again, my fren told me just press the power button, since it has 2yrs warranty. Make some sense though. Haha
kenstyle
Just switch on ultra battery mode at night when you are going to sleep. So when u wake up, charge it while you go brush teeth and get ready for work/sleep. Fast charging will help
kenstyle
I am currently using google keyboard. weird thing tt I encounter is when I try using my right thumb to swipe and type, there seem to have a little blue box blinking. And when I try to swipe words, it somehow didn't have a blue line to follow my thumb motion but rather a blue box expanding and when I lift my thumb, the blue box will appear and blink.
Anyone know what is tt?
ZhuTou!
jcbcorp
Any idea which Singtel outlet still have space grey? Call 1688 n was told only left gold.
