Huawei Matebook X Pro
Tuakong
Yup using the original charger still can feel the current
Waiting for my new 3pin charger to arrive to see. If still have current
FlushX
The aukey 60w charger from carousel
Comes with 3pin
Expecting delivery tmrw
expensive though. Energea has one with 60W PD for $50+?
https://www.hachi.tech/accessories-...ite-pd60-wall-charger-gunmetal--6957879460289
for now i'm still holding off my purchase since i mainly charge at home. usage still quite low outside.
trenzterra
This is fake 3pin, i.e. plastic top pin, so it won't be grounded. At this price, the Mazer is a better buy with an additional QC3.0 port.
The Aukey also looks like a fake 3pin charger?
So far I only found this Lenovo 65W charger: https://www.lenovo.com/sg/en/access...ADP-BO-65W-PD3-Type-C-Adapter-UK/p/4X20M26276 and the MacBook USB-C charger provided you buy the extension cord.
suxalot
I just received my i5 model and started it up today, but found that Windows 10 is really laggy and stuttering. The only changeI did was to delete my D drive partition, so as to enable Windows 10 to run on the full 256GB of SSD.
Should I wait for a couple of days and monitor to see if it gets better?
tutonic
Leave it on for a full day. Update all your drivers via the Huawei app. New laptops are generally a bit slow for the first couple hours since it's running all the updates in the background.
My matebook x pro is still as snappy as when I first got it 2 months + ago.
suxalot
Thanks bro. I also disabled my panel refresh which helped a lot with the stuttering in chrome browsing.
xJeris
anyone else bought from MS store with less than 150 USD delivery & GST charges?
s7460597
Saw the Matebook d Intel core i5 for rm2999 at Huawei shop at aeon Bukit Indah. 2 year warranty. Quite tempted.
The Matebook X Pro i5 is in stock. Need to place order for the i7.
FieldName
Confirm RM2999? If it is I'll go tmr and buy xD They got they say need wait how long for i7? Did you see any matebook x pro over there?
Edit: I read wrongly. ps. How much was the i5 x pro? Do you rem?
1000fist
u sure is 2999 and not 4999?
s7460597
4999 shld be i7
Thanks for the correction didn't pay attention to the X pro as it's over my budget. My bad.
Is the Matebook d screen touch enabled? Could find the answer.
s7460597
They've demo set of the Matebook d and Matebook X pro.
Didn't ask how long the wait. The cheaper Matebook x pro model is rm4999.
Tuakong
My skin for the matebook x Pro
Like a piece of marble tile lol....
FieldName
Very nice! If only can use pen. Wanted to buy then I read online they say this one cant use pen. Wanted to get one to write notes. damn wasted bc its a really good laptop
