Huawei Matebook X Pro
LIN_JOEL
What good is it when you can't use it with a mouse or trackpad? You will tired your hand moving around a big screen. Furthermore, no headphone jack. if you add it up with the keyboard and the pen, it is so expensive.
I need something that is portability, can watch movies and some simple excel work over the weekend out of house.
Happens to see good reviews for matebook, so got it after considering to sell my rig.
No regrets getting it, just that iPad is lighter :s13:
lamtw22
For light laptop, both LG Gram 13 or 14 are less than 1 kg and with long battery life. iPad Pro 12.9 with the keyboard would probably exceed 1 kg.
trenzterra
This is the smallest and lightest charger for USB-C 60w laptop and can charge mobile phone and tablets as well.
https://www.hachi.tech/accessories-...-60w-usb-c-laptop-adapter-intl--4710901739935
Otherwise, I think the Xiaomi 65W is the cheapest charger:
https://www.qoo10.sg/item/ORIGINAL-...UTPUT-TYPE-C-PORT/620128985?banner_no=1305330
The Xiaomi 2 pin doesn't have the "holes" you usually see in the flat 2 pin plugs. So doesn't really plug in very securely.
I am using this: https://www.hachi.tech/product/5055517351904/mazer-energ-m-egtravel-262c-65w-usb-c-pd-30-quick-charger
Has an extra qc3.0 port too. Do note that pd is only at 60w though.
LIN_JOEL
suxalot
Ash
Hi, can share where you guys order your hwmpx? Am looking for the amd version
suxalot
Is there an AMD version? I think you're referring to the Matebook D? I pre-ordered mine via Lazada Malaysia with the help of my friend.
nachocheese
No disrespect just sharing what I observed at Tech Show
https://images.hardwarezone.com/gallery/thumbs/0/sg/2018/the-tech-show/lenovo-8.jpg
Lenovo Yoga S730 can be had for $1,799.
Whiskey Lake i7+ 16gb + 512SSD + Local warranty ( "Cons : 13.3” FHD -16:9 as opposed to Huawei's)
Im also monitoring hwmxp and newer offering with whiskey lake.
The lack of warranty with high usd exchange rate combination is a show stopper for me.
Will definitely buy the matebook if it is at 1200usd range like the ms promo earlier.
Btw, the lenovo brochure shows 1999. 1799 is the onsite rate?
$1799 is onsite. Suspect sunday can go lower....not sure they will throw in more freebies or not....
nachocheese
Tb 8688rmb is base model i5 + 8gb/256.
i7 16gb/512 is 12988 for most tb stores. Still nt worth it
trenzterra
Just wondering, does anyone know of a power delivery charger with 3 pin plug? Realised when I use my mazer charger on my laptop (not matebook X lol) I sometimes feel a bit of grounding current. Checked around and it seems normal for 2 pin
dingdung
I use the three pin charger from my mbp 15 on both matebook x pro n mbp also will feel the current on both laptops.
