Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
Gixxerfied
Look like side adhesive only
Posted from PCWX using VOG-L29
Seems to be so since no glue down effect when applying. Key is something to protect the screen first..Give it 1-2 months more and more TG would be out in the market..
amazingone
imak TG applied...FP not affected, original cover fit just right..
Looks like TPG VoLTE also works on P30 :eek:
Posted from PCWX using HUAWEI ALPS
LordDo0m
Very! Battery is 25% ish more long lasting than s10+ and charges twice as fast.
Still shots wise,
ultra wide shots are sharper,
General shots are snappier with slightly faster auto focus,
Low light shots are superior,
Zooming wise, don’t even talk about it.
In screen FP reader works a fair bit better.
S10+ Screen is too curvy, as a one hand user, I kept mistyping but no such issue with p30p or m20p
User experience on overall phone fluidity wise, not much diff, close enough
(Although s10+have better screen, better videography, way better slow mo video)
P30p can be heavy if you’re not mentally prepared.
Btw I just got my tp w loca glue done by MobileLite’s Jimmy.
His is WSD grade but cheaper (and wsd doesn’t support Huawei by now I think). Fits like a charm and the on screen FP is not affected at all. No joke
Can share pics of phone with RT and also what case are you using?
joeey
Collected from pop station from singtel, free watch intact.
amazingone
Sharp eyes..Yes it works without doing anything to it..
I saw the long carrier name on the top left and was wondering which telco is that, then I saw TPG and a VoLTE icon beside it. :s13:
Maybe new Huawei phones comes with default support for TPG VoLTE.
kiawui
Just received the phone today and now there is an update already.
Sent from HUAWEI VOG-L29 using GAGT
altca4
Go fb search mobilelite and my set is used as his model.
My spigen case is that wee bit too tight so changed to his clear case.
To be fair, I prefer my spigen case but LL due to SP
altca4
for the p30 pro, if your screen is off , does pressing the fingerprint to the screen at the fingerprint sensor turn on the screen and unlock the phone? same as for the older phones where the fingerprint sensor is at the back?
Yes it works and P30p's is a lot more responsive than s10+
poppychua
For huawei... Any phone aft nova 3i all can use for tpg... Like now i use it on p20 pro....
Silverback84
Which spigen case u used?
Gixxerfied
Ya, was telling my wife ytd why their carrier name so long.. :s13:
chanbri
Nope. It doesn't work this way. For in display fingerprint only Samsung can do it. Optical fingerprint need the screen to be on.
even if the screen is off, the finger print area will light up to detect your fingerprint.
chanbri
You need to switch on unlock device in settings. Otherwise you have to make a swipe up like iPhones.
-jojo-
Hi guys. Have a noob question. For fast charging to work, does it depends on the cable or adapter or both? Thanks!
