Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
wongminmin
Hi all, hope to hear some advice, between P30 (non-pro) and Mate 20 Pro, (both roughly same price), what is some pros and cons when choosing between the 2? TIA!
Anybuttie can feedback if the in screen fp sensor works on the p30 pro with tgsp?
work fine.
technolust
rey_85
Are u able to get more bokeh effect in the portrait mode? Other than those in the phone?
KeYoKe
Can i use samsung fast charger on p30? charging seems very slow.
Different technology la brother. U should use the original cable and charging brick for super charge. Even fsster then samsung charging
Posted from PCWX using VOG-L29
Aikon
Thanks bro
Shows the optical technology is still more reliable and proven. Uktrasonic still needs nmore time to mature
Great comparison between the m20p and p30p. I came to the same conclusion at the Huawei roadshow. Only real reason to the get the p30p is the 10x zoom
Conclusion is .... Wait for m30p !! Lol
I sold off my S10 plus and got the P30 Pro. TG works fine despite of my dry hands. Better than the S10.
fighting
Omg you are right but how come need to use the original cable? Isn't it a normal type C cable?
KeYoKe
Nope. There is a chip in the cable to talk with the chip in the supercharger for supercharge. Either 1 of them is not supercharge compatible, your device will not supercharge
Aikon
Which TG u use bro
I bought from Sunday Mobile at Northpoint on third floor near challenger. $38.
The recognition rate is very good. Almost like 10/10 except sometimes finger not placed properly. Maybe it is also better optical sensor from Huawei. The S10 plus I vomited so much blood.
KeYoKe
i come from s10 plus too. yup this is definitely better then s10 plus. i dont really care about how secure it is la, but reliability is more important.
any idea whats the brand of the tempered glass? is it full adhesive?
tcchuin
Anyone has any good casing + full adhesive/UV tempered glass sp mix ?
Will prefer a matte case.
Currently using a dot matrix tp with only adhesive on the edge and it's so reflective and not good :(
cscs3
Huawei don't use QC standard. So cable and charger must be Huawei compatible to get fast charge option.
aw1007
Got my tgsp from Mobilite last week,top quality.100% works with finger print.
https://carousell.com/mobilelite
Sent from HUAWEI VOG-L29 using GAGT
