The latest version of Instagram should have fixed Stories getting cropped.
me noHi guys, recently purchased a P30 non-pro. Does anyone experience overnight battery drain? Drop close to 10% just within 6hours. Instagram app was one of the culprit but problem still persist after managing it. Not sure if its supposed to be like this.
hmmm tks for sharing. i just collected mine from singtel comcentre (the black version) and i did notice some of the sets i checked had glue residue found by the side of the phone. not sure if its from the protective plastic (that's wrapped around the phone) but it was difficult to wipe off so i requested a new set instead. Didn't spot any major flaws like what you mentioned but i do agree its best to inspect the handset thoroughly before walking away from the shop.
how big is the filesize of one photo taken by p30 pro?
if turn on full spec to take the best zoom quality..
Memory cards screwing up is something i don't want to deal with.
https://forums.hardwarezone.com.sg/120409874-post1109.html
My overnight drain over 7hrs ish is so far 1ish %Hi guys, recently purchased a P30 non-pro. Does anyone experience overnight battery drain? Drop close to 10% just within 6hours. Instagram app was one of the culprit but problem still persist after managing it. Not sure if its supposed to be like this.
And last, do take note there are Re-sealed sets in the market now. You can walk around a few shops and can easily spot them.
Huawei original seal is done very nicely with no edges sticking out from the corners. And all the seal lines are done accurately. Reseal sets can spot one. The seal lines and corners a bit all over place.
(Information sold by a shop at town area, and I went around and indeed saw a few)
Sent from Huawei P30 Aurora using GAGT
I bought from both Shopee and lazada. Working fine with my Mate 20 lol. But somehow it just doesn't work with my switch. Everything else can work.
Sent from HUAWEI Mate 20 using GAGT
Most of the time I'm using anker multiport + note 7 usb c cable to charge also. Should be safe ba since it doesn't heat the phone up as much as using a PD/Super fast charger.erm....i am using samsung charger & cable to charge switch...dunnoe safe anot.
auto brightness drain battery ?
Sent from HUAWEI P30 Aurora using GAGT
so far no issue for mine leh...touch wood
guess gotto do backup frequently now
Quick questions please:
1. The camera doesn't have a embedded QR code reader - do I have to download an app for that?
2. For Google pay at merchants, that's up to individual bank card right? What are some banks which enable it?
I do know that such things happened. But it's slightly early for that to happen to a new launch phone.u mean now then u know un-seal and sealed and un-seal and cycle continue till 1 buy the set?
lucky plaza got few shops doing sealing services already
huawei shop shuld be safe or get in DFS if u travelling
Power button + volume downAnybody know how to change the take screen shot setting? Somehow sometime when I double knock knuckle. It didn't capture. Or I'm not good lol.
Came from OPPO which is 3 finger swipe.
Sent from HUAWEI VOG-L29 using GAGT
