Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
Aikon
I find it reliable leh... Your knuckles too soft lah😋... My bony fingers everytime nail the double single knuckle knock...
Or maybe the screen protector?
samsungXP
can share wat case u r using ?
Sent from P30 Aurora using GAGT
superio
Help! I bought the UAG Frosted casing for my P30 Pro but after putting it on, my tempered glass came out.
Anyone knows which tempered glass/SP would be suitable with the UAG case?
vaxvms
Anybody know how to change the take screen shot setting? Somehow sometime when I double knock knuckle. It didn't capture. Or I'm not good lol.
Came from OPPO which is 3 finger swipe.
Sent from HUAWEI VOG-L29 using GAGT
knock harder
dun worry crack the screen
crack go chg it since within warranty period to chg
joking lah won't crack so easily
nitehawk80
Guys if you all wanna integrate SimplyGo for your travel needs. Huawei p30/pro works.
Simply just install Google Pay. (Install simplygo app if you wanna track transaction)
If you have nfc ezlink. Turn it off by going into your sim nfc services. There are functions where you can turn it off.
To tap your bank card for transport. Just unlock your phone and tap it on the terminal.
Just tried for bus and mrt. Works like a charm.
How do you turn off nfc ezlink services?
samsungXP
that case too thick.spigen rugged armor is ok ord
Sent from HUAWEI P30 Aurora using GAGT
