Huawei P40 Series
vaxvms
GMS still as easy to install as the past leh.
just installed for a friend's p40 pro recently following Youtube guide.
one time gao dim.
yup now is just a click or 2
unlike last time follow xda is OMG for non-techy ppl~~~~~~~~~~~~~~
brx1987
Hi ,
which youtube u follow? Does Singpass work ? Thank you.
my colleague uses a p40 pro no GMS sideloaded.
according to her singpass works wor.
So i not sure what is the commotion about.
Unless after sideloading GMS, singpassa dont work?
Finally got my p40pro... camp in Carousell for 1 month... and last night happen to see a 1 day recontact set from a seller @ $ 750. 😝 no GSM no problem .
No GSM of course no problem. GSM is 2G standard and no longer supported in Singapore. 😀
I think you mean GMS. 😀
Yuripa
Quick question, can the p40p and p40p plus use the same phone case ? I see the dimensions and cam module like almost the same
The camera bump on the P40 Pro Plus is noticeably larger than the P40 Pro’s, with the P40 Pro Plus being half a millimeter thicker than its younger sibling. This is because Huawei needed a little extra space to house the new periscope telephoto lens.
Everything else remains the same.
Sent from Peach Valley using GAGT
ecneret_eel
is it easy to get glass screen protectors for this phone? or does the curved screen give issues?
BuZhiDaoLeh
Hi ,
you can follow this video as recommended by another bro here in the earlier post. i used the same video guide as reference.
as for the singpass im not sure if it works cos i only helped him to install, test that the playstore etc is working as intended then i left. but you will most probably need a bypass for singpass to work.
sstimo
Carousell notification wotks?
