Huawei P40 Series
sstimo
What are the risks?
Sent from Peach Valley using GAGT
All the apps may not be google play protected so all personal information are not secured. Not worth the risk..thats why need to tweak to obtain gms...
Yuripa
Personally, it largely depends on user. If you don't anyhow install unknown apps or surf unknown websites or even set your Bluetooth / NFC to discoverable all the time, you have already done what you can to minimise any possible risks of external data intrusion.
I was using global rom on my export xiaomi mimax 2 and I side loaded GMS onto my China rom mimax 3 without unlocking boot loader and I could use WhatsApp / Banking apps / grab app / Google maps without any issues.
Anyway, like I said. Users of current huawei phones should be capable of understanding the possible challenges they will face if they were to use a P40 series. But for reasons unknown that they don't, then just change phone loh, back to a GMS model or a iPhone lol
Dahawk
Has anyone faced any issue of any apps not being able to work even after getting oscar to sideload GMS on a P40pro?
Be it banking apps, company apps etc
benqdell
Thought this Oscar fella always proclaims he can get gms to work without issues, still charging ppl $30/installation cause its "company" policy.
What a joke.
Sent from Mars using GAGT
OutBreak
Why does banking apps needs GMS? I think you got scam..
Dahawk
What a joke.
Apologies if my message was vague, i was asking for any feedback for any supplementary issues. I have not engaged his services as yet.
sos911
POSB, UOB, Dash all works in my P40 Pro without GMS. The only app that still yet to work is OCBC, there was an error msg or something when I was trying to install
Sent from HUAWEI ELS-NX9 using GAGT
sos911
Actually what is the point of getting GMS to the P40 series? Once you update the software to higher version, GMS will likely not working.
The only thing that needs to get it work for me is SingPass mobile, OCBC and tracetogether app.
Dahawk
Thank you for your input. I understand the risks at hand if i were to procure a P40Pro with regard to GMS. Just trying to weigh the risks at hand before doing so. I am an avid user of android auto (google maps) / fb/ whatsapp etc.
sos911
I see. Since you drive then I would recommend not to buy P40 series or Huawei phones. Unless you can find alternative solution of using maps other than G. Map.
OutBreak
No Android auto. Only Here WeGo map, TomTom Amigo etc.. Waze is not out yet, you can sideload with Petal Search.
pipika
Just unboxed my p40 pro... so excited :s12:
Want to ask, I normally use google map to suggest bus route to go somewhere.
Is it worth loading GMS for it? Or is there any other apps I should use?
The rest of the stuff I use that I know uses Google is
1) Gmail which I understand is not a problem
2) ACalendar that pulls my calendars from google (can live with local calendar- just that google calendar makes it easier when I have to change phone/reformat)
Is it worth side loading GMS for these usage only?
pipika
Decided to go with side load and followed the guide in English.
It is the same steps as another user who posted earlier in Chinese. Only language difference
https://www.youtube.com/watch?v=9fTIZFehwlw
Got my google map!
pipika
was it complicated?
how long did you take?
Very simple. Just follow the youtube video.
Took me about half an hour. I was lucky that my phone was always going on a step by step as per video, the success, the snags.
Now I am wondering which calendar to use. The previous 3rd party calendar I used in place of google seemed not to be able to sync with google calendar now.
ecneret_eel
shioks!
always great when what you see is what you get lol
google photos working well?
1982-1994
business calendar pro or
business calendar 2
you can create different accounts of calendar and backup them in your phone or nano card so that you can restore them on another phone
been using the Pro version for 9 years
Yuripa
Anyone here not using GMS?
Personally my biggest issue for jumping from 30 Pro to 40 Pro + is not being able to backup / restore WhatsApp massages.
My 2nd biggest issue is I play clash royale and make in-app purchases via Google playstore.
I don't mind using HMS as long as my concerns can be resolved and I understand that I can use phone clone function from old phone to new phone but I doubt it'll solve the above issues.
For existing GMS users, how many times have GMS stopped working for you? And do you need to re-install GMS again?
Thats the hassle that I'm unsure if I'm willing to go through :(
Sent from somewhere out there using GAGT
