Huawei P40 Series
siongbb
Hi. Does this phone work with Google pay?
Has anyone try using dual space to install play store...Does it work?
Soulfly
Hi everyone. I know that the P40 Pro comes with a pre-installed screen protector. I'm wondering does the P40 Pro+ comes with a pre-installed screen protector too? Thanks...
tohchr
Yes, it does
Soulfly
As mentioned over here by the bros, no matter what form of GMS sideload you use, Google Pay will not work. As Dual Space and GSpace, they both work but there are tons of ads in the app. I personally feel that GSpace works more stable compared to Dual Space. You can download both apps from the Huawei app gallery...
Soulfly
My P40 Pro+ screen has recently lost its sensitivity and has blue green lines at times. Will Huawei Service Centre check it out since it's still under warranty?
Ye_Rongtian
Of course. Lines appearing on the display is a hardware issue.
Soulfly
Thanks for the reply. The screen problem only started happening recently and at times will go totally black after those blue and green lines appear. Will drop by Huawei Service Centre once they are open after CNY...
yhw22
Just got a update for P40 Pro+ with Jan 2021 security patches.
Sent from HUAWEI ELS-N39 using GAGT
Exori80
Hi all, I’m an iPhone user currently and thinking of changing to p40 pro. May I ask if it can auto back up to cloud? And also, does the photos/ videos auto back up to cloud? I’m a tech idiot and these are the 2 things that iPhone does that kept me sticking to overpriced iPhones.
tohchr
Hi all, I*********m an iPhone user currently and thinking of changing to p40 pro. May I ask if it can auto back up to cloud? And also, does the photos/ videos auto back up to cloud? I*********m a tech idiot and these are the 2 things that iPhone does that kept me sticking to overpriced iPhones.
Yes if u use huawei cloud. U need to subscribe to storage space if u need bigger space.
vaxvms
disable anything which are AUTO 1st is my 1st task for new phone haha
than 1 by 1 auto back
yes....it is auto to huawei cloud
AcquiT
ah..am on googlifer to installl google
today change pw on google mail,now cannot sign in liao
anyone know how to bypass it without redo the steps of installing google?
saltyprince
Regret getting this phone, even after install gms
1. no notification from apps like shoppee
2. No netflix apps
3. NO SINGPASS
Gonna get oneplus 9 when its out
OutBreak
2. No netflix apps
3. NO SINGPASS
You never do your homework when buying a phone? :s8:
Its in AppGallery, why do you need GMS?
2. No netflix apps
Sideload? There are other 3 party appstore.
3. NO SINGPASS
I heard it is coming soon. But don't know when is the ETA..
saltyprince
1. IDK but NO notification from SHOPPEE or CAROUSELL, it doesn't matter app is available from playstore/huawei app store
2. U cant sideload netflix. U can't even find netflix app on Google playstore, this coz huawei no digital license support, hence u can't find/install netflix from any source.
3. Singpass not avail
4. Google pay wallet not available. Huawei wallet only support union cc in SG, no master/visa
saltyprince
Dont get me wrong, phone is good in terms of spec/design/camera BUT after a few months usage, i just want to share the inconvenience tat u can't avoid even after GMS installed.
1982-1994
personally, it's OK even if I don't receive notifications from carousell as long as no issue with SMS and telegram
don't watch Netflix, no use singpass (manual key pass on the site)
singtel dash is a good alternative to Google pay since the latter is not offering much attractive rewards
been using mate 30 Pro
yhw22
2. No netflix apps
3. NO SINGPASS
I got no issue with shopee notification.
Singpass installed but I didn't try login.
No use Netflix so can't advise.
Any issue u can go fb or carousel look for oscar debugger. He can assist u with a fee.
