jiakliaobee charsiew
- Jan 12, 2020
got smelled ur armpig?
Congratulations!15 years bbfa thanks to going gym daily
No I do at park... with a fitzai gym trainer holding you up by your legs issit?![]()
No, your assessment is wrong, ladies can do pull ups because of lower body weight not because they are stronger, many body builder with huge arms and lats also cannot do pull ups.it means your arms and lats are very weak worse than women, have seen many ladies doing pull ups
start training doing lats pull downs and assisted pull ups
Then how?if a guy can't even do 1 pull up means the body is very jialat so weak!
Lately I've having problem with this... like will have some back pain..I also can do one sit up every day when I wake up
Wah seh that's good. Jia you.15 years bbfa thanks to going gym daily
Seated row trains the lats that's correct.
But then to say it will not help much with pull up is incorrect and contradicting.
The agonist muscle for pull up is exactly the lats.
Pull up requires upper body strength relative to body weight, regardless of gender and body weight.
TS should focus on assisted pull ups to hit at least 3 proper ones. Then use a pull up ladder training program to accumulate volume.
It is not incel rubbish, the body builders have huge arms and lats and cannot do pull ups how do you explain that? It is all about mass and females have less mass, do you even lift?regardless of sex, both need to train their lats and arms to do pull ups
not because ladies are lighter so they can do pull up, what incel rubbish is this
U very bui? If so, slim down firstThen how?
Seriously I tried 1 yr liaos..
Really cannot
Any tips to improve
