iOS 10 Update Guide — [OTA Fixed]
sk0065
Strange, so many running into issues with OTA.
Maybe Apple screwed up with OTA for public release.
I'm changing the title :(
ya la
i usually OTA one ...
but from 9.0.001 to 9.000002 usually stable
now from 9 to 10
i think more stressful !
PetPet
Moderator
Moderator
If you didn't backup and you're on recovery screen, plug into your comp and use "Update" to get out of the bricked state. You do not need do a full restore. Doing so will wipe all data.
metamofia89
Wait now I'm on the page where the bar is moving after verifying update was shown. What should I see if the installation didn't work?
LunaSouL
for previous major update, usually OTA works fines for me
this one seems to break everything, so far like all fail sia
derazor
If you didn't backup and you're bricked, plug into your comp and use "Update" to get out of the bricked state. You do not need do a full restore. Doing so will wipe all data.
Kena plug iTunes :(
now Update.. <-- when select this option means back to ios 9.3.5 or ios10?
PetPet
Moderator
Moderator
Kena plug iTunes :(
iOS 10.
It should download the iOS 10 IPSW and update from there.
Edit : make sure your iTunes is up to date!
Sephir0th
trying to update via iTunes but it says require 12.5.1...clicked download iTunes nothing happened..
OTA causes recovery mode...guess it's bedtime
WestGuy
Same. So i downloaded the 12.5.1 installer from Apple website and installed it.
