iOS 7 issues
gdspd8
Hi all, yesterday just upgrading to iOS 7.0.2. I duno my iPhone 5 got any issue, I charge my phone to 100% at 12.00am and when I wake up this morning at 7.00am, it still 100%!!
When I was at iOS 6.1.4, I am very sure that when I wake up in the morning, the battery life become 89% - 92%.
What I did was the the advice stated below. I did not reduce the motion thingy.
Saving battery tips:
3. Disable certain location based services (you don't want them anyway)
Settings>Privacy>>System Services>
Diagnostics & Usage>Off
Location-Based iAds>Off
Popular Near Me>Off
Setting TIme Zone>Off (unless u travel really a lot through time zones)
Traffic>Off
4. Disable airdrop (i think quite a number of people don't use this)
Swipe up from the bottom of the screen to reveal the control centre, select Airdrop, select Off. This prevents the constant scanning for an airdrop source or target.
I also enable the Do Not Disturb with the default setting.
This morning I on my BT as my car Headunit is BT enable for handsfree call, reach office at 9.30am and now reduce to 97%.
Will monitor more.
marcusvoon
Popular Near Me>Off
Traffic>Off
Will monitor more.
i'm using Ip5 with iOS 7.02. Yes, the standby time seem to better compare to iOS7. Still drains quickly for certain apps though, could be cos the apps aren't updated to iOS7?
tingyuan
how to clear all background app when u press home button?
iOS 7 does not allow to use 3rd party usb cable. It stop charging till 87%
camoguysg
Hmm use your fingers to swipe the icons upwards. The good thing is you can now close two apps at one time. :)
gardiboy
anyone having any issues with the music player?
Sometimes when I am switching back to it, it hangs
buymyphone
3rd party cable works for me though.. just to plug out and plug it back it.. i lost my cable in a flight so just buy some random one to charge it
Thoma5
i stop using dynamic wallpaper,my iphone battery life very good now.Using dynamic wallpaper really eat battery a lot...
Shinji Kagawa
Anyone have this problem:
When using safari to surf hwz, if theres an embedded youtube video, it will not show?
I have to close safari in the background and then open it again to click on the embbed link.
But only works temporarily.
gardiboy
Can anyone wif ios 7 on an iphone test this out for me?
Try opening and closing the music app like 10-20 times.. and suddenly when u resume it, the music timing on the slider does not tally. the app than hangs but the music continues playing..
sigurros
had this problem this morning. Every time i exit the numbers app.
The phone will display a blue screen and reboot with the apple logo.
endokid
my iOS7 mail keeps downloading email attachments automatically over 4G?!?!? even 2MB files. How do I turn it off? I already disabled all the options under Settings->Mail
Thanks!
oddeye82
Hi, anybody's iphone 5 is not vibrating after updating to ios 7? The vibration on ring and silent are both turned on and the do not disturb mode is not turned on...
