iOS 7 issues
LunaSouL
So its to allow cookies? Then in the settings should be "Never", cos the title is
"Block Cookies"? So if want to allow them have to set to "Never"?
I go try see if it works. Need to go look for a GVGT thread to try. :D
i was having this shiat problem of safari crashing when clicking on embedded youtube vids in edmw, then i check my cookies setting it was set to default "From 3rd parties and advertisers"
so i try setting it to "always" and suddenly edmw is stuck in mobile mode, nothing happens when i click in desktop mode. safari still crashes when i try to play youtube vids in edmw
and everything resolves when i set it to "never"
now can playback youtube vids in edmw and safari didnt crash
ralliart12
Anyway, my 5s was setup as a new phone, & since then I'd also performed "Erase All Contents & Settings" twice on 2 separate occasions, so I don't think any of the bugs is encountered, are from residual issues of a restored backup.
anyone has problem with keypad... seems not to be sensitive as before... I keep having difficulty typing the words...:s22:
Yup, have the same feeling that the virtual keypad isn't as "sensitive"/"forgiving" as per previous; now it either doesn't capture my taps (sometimes), or doesn't as intelligently predict my next letter hit as 100% as before, e.g. it doesn't detect an "e" as easily after I typed "th", etc
There's another lag issue when you bring up the multi tasking screen. It will lag for awhile before you can start scrolling. Wonder if you guys are experiencing this as well.
Yes, I suppose you mean when you try to instantly scroll left/right through the list of applications immediately after double-pressing the home button. Yup, it'd happened to me sometimes but not all the times. But is significant to catch my attention.
Wonder if anybody is facing issues of notes, numbers and keynote app not synching at all with other device via iCloud on iOS 7?
I think for the iWorks applications you will need to explicitly turn on the "use ICloud" option in the Settings panel after you'd them installed.
On the other hand, I'm still encountering the issue where suddenly some of my Notes (sync-ed to an Yahoo account) will disappear off the phone (but remains in my Yahoo Mail online web interface) from time to time.y friend encountered this on 4s also. And the issue was also experienced by us across iOS 6 as well.
Anyone have this problem:
When using safari to surf hwz, if theres an embedded youtube video, it will not show?
Yup. May I know how to resolve this?
& lastly, I've had the phone performed a "pseudo-restart" far too many times (mostly when I'm using the Settings panel) for my comfort. There's something wrong with this OS lah(or the 5s).
ralliart12
How to get the "define" working again?
Previously after typing a word can use to check meaning, but now not working. Even I press manage, download those list of dictionaries... :(
Have you tried with other dictionaries other than "Apple dictionary"?
ralliart12
And, I've noticed (albeit only in 1 app, i.e. Atomic Browser, but also verified on an iPhone 4S running iOS7) that the long press gesture in 3rd-party applications are no longer working.
Previously I can long press on a hyperlink while using Atomic Browser to bring up a menu; but now no more.
herzog21
i cant seems to restore back all my apps to the new iphone. Anyone know how to solve this issue?
euko82
How to see video in thread?
Cannot see since installed iOS 7 yesterday
melvinhatred
mute or loud speaker activated during calls
hi anyone experience this... during calls half way it activated to loud speaker or muted? but never wanted it to... so fed up.... tried restore and reset all settings also still not working at all... no problems during IOS 6 after updating problems came.... anyone can solve?
melvinhatred
Cause ur ear touch it?
i dont think so... try to call and used my finger to test on the sensor... its still working fine... can turn off the phone screen while in calls but if i put near my ear the mute/loud speaker activated after awhile...
redevils
Me too experience the same issue in iOS 7. For me is activated speaker only
Never encounter this with iOS 6 before
szeli
long press still works in chrome
Thoma5
Mine still crash leh....:(
ralliart12
Yup, just tried Chrome in a variety of old & new devices that runs iOS7; long press works, which means I'll have to wait for Atomic Browser's developer to enhance the app.
ralliart12
Anybody notices the auto-lock doesn't work sometimes? I.E. I exit to Home Screen & put the phone into my pocket & maybe 3 out of 10 times when I retrieve the phone after a while (but definitely more than the duration I set for auto-lock timeout), the phone apparently didn't go to sleep?
Another issue I encounter is that sometimes I'm unable to exit to Home screen from the Camera app.
hazard89
Anyone a else having touch screen issues while the phone is plugged into the charger?
My screen will not recognize any touch inputs/lag whenever I'm typing, swiping, entering passcode, or just using the touch screen would cause random things to happen. Like when surfing safari, and I swipe to go 'back', a random app will just open.
The problem disappears when I unplug the charger. All charging accessories are original products.
FeNgZhEnG
moi experienced this...my screen/phone seen to lag or slow response to my fingers when plugged into charger...only once nia:s22:
xtreme84
My 4S on iOS 7 has been working pretty well. However, my 5s that I just received seems to be having some issues intermittently. Sometimes it freezes and sometimes the touchscreen becomes erratic. I hope there's a more stable version of the OS on its way.
