iOS 7 issues
Leapin_Toufu
Hey guys, my wifi greyed out and it cant work anymore.
I tried:
1. Resetting the phone/network settings
2. Blow-drying it
3. On and off it
4. Airplane mode on and off and whatever
Im still stucked. Anyone had the same problem?
Is yours a iPhone 4S? If it is, bad news, there is a possibility you had a hardware failure. Nothing to do with IOS7.
Do a full backup using iTunes, and try the factory reset. After finish bootup, if the phone never ask you to select Wifi network, then it's confirmed hardware failure.
Do a warranty claim. Or if out of warranty, go to QCD Technology at Tai Seng, pay S$350.00 to get refurbished handset.
chrischew79
I tried:
2. Blow-drying it
3. On and off it
Happens to me too. I think mine is worst. the cellular network goes on and off as well. drains my battery and heat up my phone while searching for any network. Only after I've updated to iOS 7 on my 4S as well.
vballguyy
Whenever I set my wallpaper it appears to be zoomed in and really ugly. Anyway to zoom it out like before or any other apps which can help me in doing so?
PetPet
Moderator
Moderator
Accessibility > reduce motion.
Your wallpaper is zoomed in because it's required for the parallax effect.
Lord_Kang
my iphone 5s occasionally cannot stop syncing... How to solve it??
ForumRider
just found a bug...while ungrouping all the apps off from a folder, one of the apps actually disappeared from the home screen.... the app came back after reboot.
This bug however not always reproducible...
chengsun
it has been good. but, i dun know if it is 7.0.3, or the restore from backup that i did last week (to rectify a camera issue) I find the battery life not as good after that......
thinkig of restore again. does it help?
bagger 288
Suspended
I never like to restore from backup. Setup as new better for me.
catalyxt
my phone will have a notification sound every night at 1.10am..checked notification bar but it was empty..im using iphone 5 with latest os
anyone having the same issue?
argentinafa
Check settings notification centre. Might be one of ur game. Check ur alarm.
Shinji Kagawa
Anyone figured out how to change wallpapers yet?
Now the wallpaper becomes zoomed in when i want to change.
argentinafa
settings, general, accessibility / reduce motion: Enable
Don't think enabling this will prevent iOS 7 from zooming in when u wanna set as wallpaper.
That option merely switches off the parallax effects of the home wallpaper.
This zooming in of wallpaper is quite irritating I must say. Pictures get zoomed in when I wanna set it as home or lock screen. Even if u pinch out to unzoom, it doesn't help as it'll go back to the zoomed size.
Wasn't the case for previous iOS.
