iOS 7 issues
Crimsom
Sometimes the "missed" section of notification centre does not dissapear.
e.g. I have a missed call and it keeps showing on the "missed" section and there is no way to clear them.
tapping on it calls the caller but it is still stucked there.. annoying problem
renfred89
software glitches happen everywhere, every model and every make.
If you trust the reputation of a company, then dive in and buy it. Dont make the wrong decision due to a season of flopped software. :D
orange_20
the missed notification will be dismissed after 24 hours iirc.
xtreme84
Well... I don't regret getting my 5s despite the software issues and I believe it'll only get better.
N_RIDER
With all these issues, you guys still recommend us to buy 5S? :)
Need some advice :) thkss
Can't be days before marriage, you realized that your wife to be has the little habit to fart on bed and you back off right?
Just married "her", mostly she will change(new firmware) in due course .
Slowx6
Any of you realise when u on the assistance touch, your phone tend to lag sometime?
jq75
well a big ios leap (from 6 to 7), give it a few patches to sort things out:D
malaikai2005
I went to livescore website
weird ... sometimes I cant scroll it
then sometimes it flash to main screen:s22:
I think certain websites only
is it due to java?
jq75
Hopefully 7.0.3 offers some solution to earlier issues
kuehpeng
Hey guys, my wifi greyed out and it cant work anymore.
I tried:
1. Resetting the phone/network settings
2. Blow-drying it
3. On and off it
4. Airplane mode on and off and whatever
Im still stucked. Anyone had the same problem?
comtt74
Greetings to all.
I am on M1 and using iphone 5S.
I experience very bad 4G signal using ios 7.0.2 and 7.0.3.
I stay in Yishun.
When whatsapp, messages get send out very slowly and will encounter "No internet detected".
Surfing internet using safari also painfully slow.
The above started about 3 weeks ago.
I end up switching off 4G and everything back to normal.
Guys, do you think the cause is 4G network or ios or hardware?
Please help.
Thanks.
calvinhkk
After I upgrade to ios7.0.3, my watsapp and line and this pop up msg "connect to itunes to use push notification"
Now it cant shown push notification and every now and then i need to go in to the apps and check for msg
How do i fix this ?
Mine is iphone 4 without jailbreak.
Thanks
