iPhone 11/11 Pro
PetPet
Moderator
Moderator
I'm really tempted to switch over to the regular Pro from the Max :s22:
I'm not sure if I'll regret it, the Max is rather bulky.
argentinafa
Last year did u had the XS Max or XS bro? To me my logic of thinking is, since 5.8” also use 2 hands to type, then might as well take the 6.5” using 2 hands to type. Bulkier yes, but the 3969mAh battery is a big plus point.
alan_shearer
I just switched in the other direction bro. I was using XS max and really missed the screen size when I used the Pro.
Comparing the battery life of both Pro and Pro Max I say Pro Max is better by at least 30-40 percent.
gerrickchua
I came from the X and not looking back.. Even with X I was using it with 2 hands when typing messages too so I just have to get used to the increase in bulkiness and the rest are plus points to me :)
kEvinErd
That was my thinking too previously but now that you can swipe to type, I can type with one hand on the regular pro.
PetPet
Moderator
Moderator
I came from the XS Max.
I don’t think that I would be bothered by battery life that much since I’m always carrying around a macbook (power source) and that it could be fast change.
I had the opportunity to use the X recently and I kinda missed the size. I probably have average sized hands, but it is so much easier to navigate the X as well as to take photographs with it.
I mainly use my device to mostly text and only occasionally game. I highly doubt that I will miss the screen estate considering that there's feature parity between the two sizes. You probably have some extra columns in landscape mode on the Max sizes. But I have hardly ever used my devices like that.
But thanks for your responses guys.
It’s just an idea I’m toying with.
Tomorrow is my last day to return the device and looking at the Apple Store. There’s currently no stocks for the Pro 256 :s13:
Glariel
So you planning to return?
RocketBunny
Then you'll be more suitable for the smaller device ba. Great size to hold, reminded me of my iPhone x days :(
Or you can opt for return and collection from your house, choose the latest date. So it's like 'extended' a few days =:p
*adiBOY
Stock will be replenish between 0530 - 0830. Keep a lookout within the time and you'll be able to order one Pro.
plsbanthem
I used big phones before. Never enjoyed it as it is bulky in my pockets. In short, doesnt suit my lifestyle.
Happy with the smaller pro.
