iPhone 11/11 Pro
Snoweagle
cheers! still prefer the smaller factor since I dont really watch videos on phone. cant wait to try out the much acclaimed camera in aus next week
You will enjoy it bro, trust me. I recently returned from a trip to Taiwan and used my 11 Pro Max to take all the pics, it’s awesome!!
Franky37
Hi All,
I am thinking of jumping ship to from android iPhone and was hoping to get some advice.
1. I was informed that when if I change to iPhone from an android, all my whatsapp message will not be recoverable even when i do back up?
2. I have paid for some services to unlock full features in an app. Would that be affected if I moved from android to iPhone?
3. 11 Pro or Pro Max???? Used to own an iPhone 6 and love the size. However, internally screaming for bigger screen size.
kashix
Hi All,
3) yes iPhone 11 Pro Max la, go big or go home.
szeli
Hi All,
1. pay for backuptrans to transfer e msgs
2. u have to check with e app dev
3. only u yrself can decide
benz1987
I think this was discussed before. But would you all go with AppleCare plus for your new phones?
I’m paying for StarHub smart support but was thinking which is a better option, Apple care plus or the smart support or don’t get it at all.
Cheers!
punker
Put your phone next to the nfc reader to activate Apple Pay then face scan to pay?
Don’t think u can do that. Apple Pay for Face ID always requires the user to double click the side button to make any payment. This is to prevent skimming. I guess the next best solution is to use Apple Watch, otherwise, ending the call is probably the only way
thenakedshades
Cheers!
AppleCare+
Jeremy1
If u are not planning to upgrade your iPhone, then AppleCare+ is okay but please do take note that if u accidentally drop the phone and the screen crack or there's some damages to the phone, they will still charge u for the service charge no doubt it will be much cheaper with AppleCare+.
benz1987
Thanks! But with Smart Support, a swap fee is also needed in the event of the phone is damage and u swap with a new one. It is at $280 whch is probably close to what AppleCare + is charging
kingcarlos
haha indeed! just came back. got to say its much better than my iphone x in term of speed of processing photos and hdr performance.
cnt
You can tell the difference that Deep Fusion makes with your naked eyes..?
On the phone it’s unlikely unless you zoom in. But if you crop pictures then you may appreciate it more
argentinafa
Actually can bro. I show u an example. Can u tell which picture is with Deep Fusion on?
The pic with the 2 cloths is with DF on. The pic below with one single orange cloth is with DF off
deathst
Definitely! I especially used the ultra wide lens to take all the scenery shots and some structures too.
With deep fusion now, it's even better.
Deep fusion does not work on Ultra wide lens. :s22:
The standard wide angle lens will use Apple’s enhanced Smart HDR for bright to medium-light scenes, with Deep Fusion kicking in for medium to low light, and Night mode coming on for dark scenes.
The tele lens will mostly use Deep Fusion, with Smart HDR only taking over for very bright scenes. (Night mode always uses the standard wide angle lens, even when the camera app shows “2x”.)
The ultrawide will always use Smart HDR, as it does not support either Deep Fusion or Night mode.
Deep Fusion’s is meant to offer a massive step forward in indoor and medium-lighting situations.
argentinafa
Ditto bro. Love the way how sharp pictures are. Which makes us wonder what is iPhone 12 Pro/Max gonna bring us, since iP11PM to me has already achieved optimum picture clarity quality.
