iPhone 11/11 Pro
Snoweagle
Deep fusion does not work on Ultra wide lens. :s22:
The standard wide angle lens will use Apple’s enhanced Smart HDR for bright to medium-light scenes, with Deep Fusion kicking in for medium to low light, and Night mode coming on for dark scenes.
The tele lens will mostly use Deep Fusion, with Smart HDR only taking over for very bright scenes. (Night mode always uses the standard wide angle lens, even when the camera app shows “2x”.)
The ultrawide will always use Smart HDR, as it does not support either Deep Fusion or Night mode.
Deep Fusion’s is meant to offer a massive step forward in indoor and medium-lighting situations.
I’m well aware of that. What I’m referring to is the overall camera system of the 11 Pro. :s13:
Snoweagle
Got dp? Haha
I’m using this app called ‘Metapho’. It can tell you by each of the photo’s EXIF data, whether it is ‘deeply fused’.
cnt
Both pictures are dp. Also noticed heic format is about 1/2 file size of jpg
Snoweagle
But quite bulky. Haha
Definitely bulky because of the character. I've seen a number of these type of cases for sale online and in 西门町 on my recent trip, a number of shops also selling it, but only for the regular AirPods as the Pro (until now) is still not launched in Taiwan, even though it's been in the official website for some time.
fade_white
Actually can bro. I show u an example. Can u tell which picture is with Deep Fusion on?
The pic with the 2 cloths is with DF on. The pic below with one single orange cloth is with DF off
So how do you tell from this two pics which one has DF on?
I can’t see the diff leh
MinMin85
Hi, I notice that my iPhone doesn’t indicate that there’s software or apps to update. Does anyone know how do I solve this problem? Thanks
*adiBOY
What do you mean? If there is an update to an app, the AppStore will have a notification badge shown.
class
i noticed that the price of the iphone xs is more expensive than the iphone 11
any one know why?
jaymessofly
I had this problem previously.
It was because I changed my app store's region, and did it incorrectly. It caused a problem with my Apple ID, which resulted in me not receiving any prompts for app updates.
You should try checking your Apple ID - location, payment methods etc and the problem should be fixed.
