iPhone 11/11 Pro
*adiBOY
Im using ip11 pro max.
Anyone has played with the new feature of editing picture outside the frame?
I have enabled the setting but i am unable to edit the image to include those portion outside the frame.
Is my phone having issue or did i do anything wrongly.
Thanks
Take a photo with 1x. Then go to photos, click on edit.
During editing, pinch the photo to make portion outside of frame to appear.
fade_white
0.5x using ultra wide.
1x using wide.
2x using tele photo.
Sometimes 2x could be using 1x cropped depending on scenario.
I’m referring to in between 1x and 2x e.g. 1.1x,1.2x etc (when you slide up and activate the zoom wheel.
Presto80
Tried this many times but cant.
I also realise i dont have the star indicator on the top on the screen.
Saw this indicator in one of the website
deathst
Digital when it is pass 2x everything else is cropping from their respective sensors.
It switches between cameras even when you reach their respective levels.
Note that the telephoto Len comes into play only when the system feels like there is enough light else it will use the main Lens and digital zoom.
GGGGGG
Last night when I went to sleep with the 11 Pro charged, the phone was a little warm. This morning when I woke up, the phone is still warm and my battery is still at 80%. Is it because I turned on the optimize battery charging option??
ragnarok95
Senior Moderator
Senior Moderator
Battery should only feel warm during charging, or when you are using it. If idling and not in use, it should not feel warm.
appl888
Did you use iCloud?
vengence_angels
yes it is because of optimize battery charging. the phone will learn ur usage patterns stop charging at 80% since you are not using your phone at night
it is to help preserve the life of the battery
deathst
